SS Brake line vendor - NCRS Discussion Boards
  • Jason Stavropoulos
    Anyone know of a good stainless steel brake line vendor? By good I mean one that reputedly sells kits that actually fit the car.
    Thanks in advance
    Jason
  • Dave Schenk
    Re: SS Brake line vendor
    I used a local guy in Ohio, Rudy: Fax number 330-339-6595, cell 330-327-3474,
    Office 330-339-6054. He completed the SS brake system on my 65 a year ago, worked out great. Dave #37165
    • Mike M.
      • September 30, 1999
      • 710
      Try Classic tube
      Classic Tube brake, fuel and transmission lines are pre-bent to OEM specs or custom-made for your vehicle. Find the right tubing for your classic car today!
      • Stephen L.
        • May 31, 1984
        • 3158
        I recently purchased a set of SS brake lines for a 67 NON power brake car from Crane Corvette Supply. They fit perfectly. The only thing that is annoying is the front to back line must be folded for shipment. This was relatively easy to straighten to the original configuration..... $110 + s/h.
          Re: Try Classic tube
          I did try Classic Tube, that is my reason for being here. Front to back line was too long. Left to right line was also too long and the bends seemed to be in all the wrong places.
          • Mike M.
            • 710
            They did mine and no problems *NM*
              Re: They did mine and no problems
              Did they actually install them? If they did, then I can see how they fit like a glove as it is quite easy to cut brake lines and put a flare on the end if it's too long.
              • Mike M.
                • 710
                Installed Them Myself *NM*
                • Mark williams
                  muskegon brakes in Michigan have real nice sets, I have bought 2 sets and they fit perfect on my 69 and 72
