Pistons? Powersteering?? - NCRS Discussion Boards
  • Tom H.
    • September 30, 2002
    • 136
    Multiple choice questions: Does anyone know what the pop-up cc's on the 65 FI SHP pistons? Does anyone know if I can add power steering to my 65 SHP, I know the oil pan doesn't clear- what pan can I substitute and can the PS pump take 6500+ RPM? Can I still use the same dipstick and tube with a different pan. I've lost most of my arm strength from surgery and I can no longer turn the steering wheel at rest. Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: Pistons? Powersteering??
    dome is 5.3cc. If you go to the small pan, in addition to removing the baffle and using the shorter main bolts, I would recommend going back to the low pressure oil pump as the shp pump can empty the five quart pan before tho oil can drain back from the top of the engine.
    Bill Clupper #618
    • Tom H.
      • 136
      Thank you.
