re-lube for steetring box - NCRS Discussion Boards
  • Richard D.
    • December 1, 2002
    • 328
    Was going to repack the steering box on my 68 with synthetic grease, as recommended in Richard Newton's Resto Book.
    He recommends removing the cover plate (the 3 bolts that hold it on, one being for checking and adding lube oil).
    The lash adjusting screw and locknut are on that plate, so I was wondering if any special care or steps need to be taken with the lash adjusting screw when removing the plate.
    Anyone out there with some advise on this?
    Rich
  • Eric Fairclough
    Re: re-lube for steetring box
    I went by the corvette manual i had and it said to take the bolt on the left and the bolt on the right out ( if your looking straight down at it ) and put a grease gun extension in the left bolt hole and pump it till it squishes out of the right hole then thats it. I did this on my 72 and it steer alot easier. Of course i also had to use one hole big tube of grease because it was all dried out. I think it was never touched before i did it. Eric
      • 15676
      I recommend you follow Eric's advice and use the procedure from the service manual. If you remove the steering gear cover, it will be virtually impossible to re-establish the same gear preload.
      • Clem Z.
        • January 1, 2006
        • 9427
        you can take a similar bolt,drill and tap it for a grease fitting and install it on the one side with the bolt on the opposite side out and grease till grease come out the empty bolt hole.
        • Richard D.
          • December 1, 2002
          • 328
          Thanks to all for the great advise.
          Rich
          • Pat L.
            • April 1, 2001
            • 76
            What is the correct type or weight of the lube that should be used in the steering box?
            • Clem Z.
              • January 1, 2006
              • 9427
              i would use a moly based chassis lube as this will reduce some of the friction.
