'67 Parking Brake Cover Color - NCRS Discussion Boards
    Does anyone have a chart or definitive knowledge of what color the parking brake cover should be on a '67 with the code 450 combination white/blue interior? The TM&JG says the cover "should match the seats" (white with the 450 trim), but I have also seen them in blue, which continues the blue color of the console back to the blue-carpeted division panel. The A.I.M. shows #3897370 chart for the cover (which would show which molded-in-color cover went with which trim combination), but I have no idea what the chart actually showed.
    • 43221
    Re: '67 Parking Brake Cover Color
    John----
    The GM specs for the cover with combination trim 450 call for it to be white. The original part number for the white cover was GM #3899281.
    • Wayne W.
      • April 30, 1982
      • 3605
      I have had both W/Bl. and W/Bk, both had white brake covers.
        • 43221
        Wayne-----
        Yes, GM specs call for both combination interior coded 450 (white with blue) and 455 (white with black) to use the same white console.
          Thanks, guys - mine's blue - now I gotta go hunting for a white one
          • Kent K.
            • December 1, 1982
            • 1139
            John, My '67 had the original white/blue interior in it when I bought it from the third owner. The parking brake cover (housing) was and still is white.
            Kent #6201
            Kent
            NCM Founder - Member #718
            • Donald O.
              • May 31, 1990
              • 1588
              John,
              Is the plastic itself blue or was it painted/dued blue?
              My white cover is more like a milky creamy color. Not a true white on the inside, but it was dufinitely spray dyed white on the outside. I would try to remove the blue dyr/paint and redo it in white.
              Don
              • G B.
                • December 1, 1974
                • 1407
                Yes, it was white when I got it.
                But I did repaint it once in the mid-seventies.
                • Kent K.
                  • December 1, 1982
                  • 1139
                  Re: Yes, it was white when I got it.
                  Jerry, You continue to amaze me with more historical facts about "our" '67! The parking brake cover housing was also a milky-white plastic material ... reproductions I've seen are black and you have to paint them whatever color suits the interior. (Pictures available for documentation at Winter Regional Meet in Kissimmee, Florida.) See you there?
                  Kent #6201
                  Kent
                    Don -
                    The original parts were molded in trim color, not painted; if they show signs of overspray, someone has painted or dyed them.
