Drag link repair - NCRS Discussion Boards
Drag link repair
  • Dwight Farmer
    Drag link repair
    Does anyone have info on 58-62 drag link repair. Looking for info on assembly procedures. Thanks.
  • James F.
    • December 1, 1985
    • 596
    Re: Drag link repair
    Dwight, Assembly order, first, cotter pin, end plug, spring, ballseat. Then there is the pittman ball coming in through the opening. Continuing on there is, ball seat, plug, spring. With wheels straight ahead, tighten end plug until springs are compressed and plug bottoms then back off 3/4 turn plus amount to insert cotter pin. As your question was not specific I'm guessing this may be of help. Regards,
    • James F.
      • December 1, 1985
      • 596
      • Bill Clupper
        Dwight, If Jim's info isn't specific enough, get a copy of any old pass car shop manual, (I'm using a copy of '49-53 Chevrolet edition for reference, & the Drag link is covered in the same section as the steering box-referred to as "steering Connecting Rod Assembly" in my book (Section 9)
        • Bill Clupper
          • John
            If you buy a rebuild kit, make sure the replacement ballseats have holes drilled through them to provide a path for grease - I've seen some rebuild kits where the seats don't have the holes in the center, and the only grease those joints are ever going to see is what goes in during assembly.
            • John
