69 frame mounting - NCRS Discussion Boards
69 frame mounting
    • 15606
    Re: 69 frame mounting *TL*
    1973 + body mounts are all rubber.
    • Jim T.
      • March 1, 1993
      • 5351
      From what I know, the convertible uses different mounts at body mount locations 2 and 3. 1 and 4 on the convertibles use the same mounts as what is at all body mounts on the coupe. The rubber body mounts for positons 2 and 3 have a different spring rate and had white marking on the rubber mount so they don't get mixed up with the mounts for positions 1 and 4 after they are removed from the parts box.
      • Harmon C.
        • August 31, 1994
        • 3228
        Thanks Jim The ones I have had never told where to put the ones with the white line.
        Lyle
