Re: '65 trim tag info
Brian, given only the 67 467 style code that you posted initially, John Rohe's reply was correct, insofar as this indicates a 1967 convertible body. Now that we know you have a '65, you should verify that the code should read 65 467.
As with all things GM, there were many variations. Trim tags began on Corvettes in 1963, then a second body line was added in Dec '63, at Ionia Michigan (A-code bodies, for A.O.Smith). Early '65 S-code convertible bodies (produced at St.Louis) had the full 65 19467 as the style code, with later ones dropping the 19. But the early "A" body tags did not identify the year [19 467, even omitting the 19 from about the first 800 cars (per N.Adams,Vol 2)].
You mentioned possible option checks; if you have an interior color other than black (vinyl or leather), it is possible to identify certain options from the trim code that impacted the body; example: a '65 S-body convertible with saddle leather, power windows and automatic trans would have the trim code of 421BJ, because these options and colors affected the choice of center console. Things improved even further on '66 and '67 trim codes, identifying combinations of options A31, A82, A85, C07, M35, N03, but ONLY if the interior is not black.
As for other options, PS, engines, etc, the best you can do is get hold of the '65 factory assembly manual and check out all the tell-tale mods or variations required for these options. Good luck
