C2 Front Licence Mounting Question - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    In the 1966 TIM manual it states that the licence plate bracket is "stamped to accept two white plastic nuts for licence tag mounting" Also, the AIM shows them as round to me. The ones I got from L.I. Corvette Supply are square, not round. Anyone know whats correct or where I can get the correct parts?
    Thank you for your help.
  • Henry J.
    • November 1, 1999
    • 457
    Re: C2 Front Licence Mounting Question
    Kurt, in my copy of Peter Licastro's book "Birthplace of Legends" there is a excellent full-front photograph of a newly completed 66 undergoing the "water test" in the St. Louis factory. I have seen this photo appearing in other publications as well (probably in Noland Adams' book, if memory serves). The licence plate frame and the white plastic licence mounting nuts are clearly visible. Under a magnifying glass, these nuts appear square to me.
    When I removed the licence frame on my 66, the plastic nuts I found there were very old and very brittle. I took them to be original, but who knows for sure. They were square too.
    I hope this helps.
    • R N.
      • May 31, 2002
      • 640
      Thank You Henry *NM*
      • Rob A.
        • December 1, 1991
        • 2126
        The square nuts are correct. By the way, if you purchase items from Long Island Corvette, they don't mind if you tell them you only want the part(s) if they are correct, such as headmarking on bolts, etc., they are very knowledgeable and accommodating.
        • Tom Merkel
          Kurt - My '67 front license plate bracket is in-tact and on my workshop shelf since new. The two plastic inserts are square and white (although faded to 'dirty white' lo all these years.)
          Perhaps '66's were same?
          tm
          • R N.
            • May 31, 2002
            • 640
            Thanks Guys
            Henry, Rob & Tom:
            Thank you for the confirmation. I'll proceed to install the square plastic nuts.
