R&R seat belts - NCRS Discussion Boards
R&R seat belts
    • 11643
    R&R seat belts
    Hello all,
    I have some black lap belts that are in decent condition as far as fraying is concerned, but a couple are faded, and all are very stiff. The stiffness makes them quite difficult to use.
    Is there a "sure fire" way of "un-stiffening" the belts? I've considered washing them, but won't if the only way to fix them is to re-web them. They're great original, Survivor/Bowtie type belts otherwise (great date codes, labels, lack of fray, etc.), so I'd hate to re-web them just for the sake of doing it.
    In addition, would a little spot-applied black Rit dye take care of the color?
    Patrick
  • Dave S.
    • August 31, 1992
    • 2925
    Re: R&R seat belts
    Patrick,
    I just had Charlie at Seatbelt City do over a set of 61 seat belts for me. He took some parts in trade and made a set which was show quality and correct for my car. A real gentleman to deal with and performed the work in less than 2 weeks. I would give him a call and he can advise you accordingly. He's an NCRS member and Driveline advertiser. He mentioned to me that he would be in Orlando in January.
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: R&R seat belts
      I Use Tuff Stuff foam cleaner from the auto parts store on seat belts and black spray dye. I would not reweb good looking original belts as their are many ways they can take away points on reweb jobs. They got me and they were correct so I just said OK.
      Lyle
      • Gary S.
        • July 31, 1992
        • 1632
        Re: R&R seat belts
        Patrick, I had real good luck cleaning up a Carlisle-purchased set of 66 set belts that were almost totally stiff. All I did was to pull the seatbelts out and clamp the retract mechanism so it wouldn't retract. I soaked the belts in Simple Green and then scrubbed with a soft bristle brush. The water turned brown when I rinsed. I kept repeating this until I could rinse and get clear water. I let them air dry and then worked on the retract mechanism. I have no experience dying or tinting belts though.
        Gary
        • Rob Dame
          Re: R&R seat belts
          I would think a nylon dye would work,a carpet dye perhaps.
          Something that won't come off on your clothes.
          Rob
          • Bill Stephenson
            Re: R&R seat belts
            ------Once you have cleaned them as the above posters told you to,try a permanent black majic-marker.Worked great for me..........Bill S
            • David B.
              Infrequent User
              • January 1, 1992
              • 15
              Re: R&R seat belts
              Charlie at Seat Belt City is the way to go. He restored my belts.
              908 719 2354
              David
