I just purchased an accelerator return spring (with 1X4 amd automatic). After comparing it to the spring currently on my car, I understand why other restorers talk about the spring not being strong enough to bring the engine back to idle. The repro. spring is one inch longer (5-1/8") from tip to tip than my old spring (4-1/8"). I don't know for sure that my old spring is the original, but it always brings the engine back to idle. Is the longer spring correct, just weaker than the originals? Or is it incorrect? Anyone found a brand of paint with the "lime green" color?
Question: How is the kick panel windlace attached to the lower five inches of the kick panel? Glue? Can't use staples there because they will show. Does it drop straight down the side of the kick panel the last 5 inches?
