C3 (1979) Spicer U-Joint Part Numbers? - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    What are they for a 1979? And where might these units be purchased?
    • 43238
    Re: C3 (1979) Spicer U-Joint Part Numbers?
    Paul-----
    The original-style Spicer u-joints are no longer available through GM. I would suggest contacting a Spicer Drivetrain retailer and obtaining a set of current Spicer u-joints which are similar to the originals.
    Original u-joints used on your car used no grease fittings. Currently, I believe that the Spicer joints with grease fittings otherwise look the most like the originals. The "Lubed-For-Life" type, which have no grease fittings, are now, I think, configured differently than the originals. But, your best bet is to check with the dealer and look at both types.
    • Paul L.
      • November 1, 2002
      • 1414
      Thanks Joe. I understand the part numbers for the C3s changed recently. And that was the crux of my question. Interestingly the best source of Spicers now seems to be heavy truck dealers such as Mack. They seem to have the numbers and the sources.
        • 43238
        Paul-----
        The original part numbers for your car were as follows:
        driveshaft-----GM #390133
        half-shaft-----GM #374246
        I don't think you'll easily find any of the above-referenced, though.
        • Paul L.
          • November 1, 2002
          • 1414
          These were the Spicers I used two years ago: 5-618X for the drive shaft and 5-627X for the halfshafts. But apparently these numbers are no longer valid?? There must be superseding numbers.
