Re: power master cylinder - NCRS Discussion Boards
    • 43221
    Rob-----
    I really don't know when the dating of the master cylinders started (or, possibly, ended). So, it's very hard to say what the origin of this master cylinder is. Given the very small number of J-56 Corvettes built in 1967, the chances that it was a PRODUCTION unit are quite small.
    Just so there is no confusion, though, the dates that were present on Corvette master cylinders of this era were not casting dates. They were manufacturing assembly dates and are found stamped on the flat machined surface of the forward brake line fitting boss. They are quite small and lightly stamped. They could be easily removed if the machined surface was even lightly spot-faced.
    Keep in mind, too, that it's not absolutely impossible that the unit is original to your car. As I mentioned, I've never seen one and GM production information does not indicate that any were used. But, that still does not mean that absolutely none were used. Although rare for components like a major brake system item, exceptions do occur. Unfortunately, if the unit is actually original to the car, I don't know how you could document it. This is one of those cases in which one may have to make his car "original" by making it "non-original".
    If your car were an extremely late-build 1967, I think that might increase the possibility that the '346' was originally used. However, that still does not represent anything close to "documentation". Based upon what is known about 1967 master cylinders, the '346' is incorrect for your application. By the way, is the master cylinder coded "PG" on the front, machined surface and does it have bleeder valves?
  • Rob A.
    • December 1, 1991
    • 2126
    Joe, It does have a machined area in front, however, I can't make out any letters. I does have the two bleeder valves. I'll be replacing it with a 509 for judging purposes, and would like to see this one installed on a car that requires it. Thanks for the quick response.
    • Rob A.
      • December 1, 1991
      • 2126
      Joe, Upon close inspection I did find PG2196 on the machined surface of the forward line attachment. I assume this is for the 219th day of '66.
        • 43221
        Rob-----
        Actually, in the julian date coding system used for these master cylinders the year is represented by the FIRST digit of the numeric code. So, in this case, the master cylinder was manufactured on the 196th day of 1972. The '346' master cylinder casting was used well past 1972 and, for 1972, the bleeder valves were still being installed on these castings. So, the master cylinder that you have is entireley consistent with a 1972 vintage m/c.
        Also, the 219th day of 1966 was August 7. However, August 7th that year was a SUNDAY. So, it's very unlikely that the cylinder could have been manufactured on that day. The 196th day of 1972 was July 14th which, for 1972, was a Friday.
        • William O.
          • April 30, 2001
          • 355
          Isn't the 1967 J-56 master cylinder casting number: 5480346 not 5460346?
          Bill
            • 43221
            Bill----
            Yes, I believe that 5480346 is correct.
