Installing Engine on '62. - NCRS Discussion Boards
  • Don Ursery
    I'm getting ready to install my engine in a '62, 340hp, 4-speed. Is there anything I should install prior? I've installed new brake lines, fuel lines, mufflers & pipes? I have new wiring harness. Everything has been removed from engine bay...has anyone learned from previous installs? Battery? Wiper motor? Thanks for your help.
    Re: Installing Engine on '62.
    Ray -
    Steering column/gear assembly (with pitman arm installed), if you haven't already done that.
    • Ed Jennings
      Be sure to install teh fuel pump on the engine also. It's a PITA to install with the engine installed.
