'67 Rear Spring Replacement - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    Since receiving a Duntov Award in '94, the original rear spring in my '67 has succumbed to prolonged forces resulting with zero arch. I have a new Eaton spring, painted it and am ready to replace the original. I have misplaced my AIM and could use some help. Before starting, are there any procedures requiring extra careful attention on which anyone experienced could provide advice?
    Many thanks in advance and Merry Christmas to all.
    Kent Member #6201
    Kent
    NCM Founder - Member #718
  • William C.
    • May 31, 1975
    • 6037
    Re: '67 Rear Spring Replacement
    Hi Kent, use the weight of the car to load the spring while unbolting the link to the suspension arms, and also while loosening the bolts on the differential cover support (loosen these, do not remove) then raise the car to take the weight off the spring, finish unbolting the bracket and make sure you have a good hold of the spring or get out of the way when it comes off. Reverse steps to reinstall, do not torque the center bracket to (anywhere near) full torque until the spring is supporting the full weight of the car.
    Bill Clupper #618
    • Kent K.
      • December 1, 1982
      • 1139
      Thanks for the tip Bill. As I remember, you cautioned me about the rear spring being in baaaaad shape while it was on the lift last year. Time to take action, eh? Have a wonderful Christmas.
      Kent
      Kent
      • Ray C.
        • June 30, 2001
        • 1132
        Hi! Bill
        I am also in the process of re-installing my rear spring on my 65. Is there any tricks to compressing the rear leaf spring until the bolts, cushions, and washers can be installed. I am in the process of a body-off, so the only weight will be the componets that make up the rear suspension.
        Thanks for any help
        Ray
        http://home.rochester.rr.com/carneyscorvette
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Stephen L.
          • May 31, 1984
          • 3158
          Ray, I recently installed my rear spring with the body off. What you need to compress the spring is a lot of ballast or.... Have someone sit on the frame to keep the frame on the jack stands for stability..... then using a 2x4x8ft on edge carefully insert the 2x4 in the frame members from the rear and have a "hefty" person hold the frame down. Now using a floor jack carefully jack up the spring and insert the bolts etc. Be careful when doing this as a slip could hurt someone.....................you are jacking against the person holding the 2x4
          • William C.
            • May 31, 1975
            • 6037
            With the body off, I looped a chain around the spring and used a hydraulic "bottle" jack on top of the frame to pull the spring into place. All the previously mentioned cautions about the caution required and the amount of energy in a compressed spring still apply
            Bill Clupper #618
            • Ray C.
              • June 30, 2001
              • 1132
              Thanks Jack!
              Try it tomorrow.
              Ray
              Ray Carney
              • Kent K.
                • December 1, 1982
                • 1139
                Is it possible to replace the rear spring without first removing the mufflers and exaust pipes? I have the spring links and center plate-to-differential bolts loosened. Also, it looks like the differential plate bolts mat need replacements. Are these available and from whom?
                Kent #6201
                Kent
                • Donald O.
                  • May 31, 1990
                  • 1588
                  Kent,
                  Not only is it possibe, but that is exzctly how I did to my 67. The entire job took about 3 hours using the Service Manual as a study guide. It tells how to remove, how to install and what tools to use. A relative piece of cake.
                  Don
                  The light at the end of the tunnel has been turned off.
                  • Kent K.
                    • December 1, 1982
                    • 1139
                    Thanks Don. I'll probably remove the exhaust pipes and mufflers just to allow more room installing the rear spring. Now, if I could just get my Sears 2-ton hydraulic floor jack to lift past about 30 degrees (it's supposd to lift to about 85 degrees) ... :-(
                    Kent
                    Kent
                    • Craig S.
                      • June 30, 1997
                      • 2471
                      Kent - usually this means you are low on jack oil, you may want to check....Craig
                      • Kent K.
                        • December 1, 1982
                        • 1139
                        Thanks Craig. According to the instructions on the jack oil I just purchased, I should have been changing it more frequently. The jack has a '88 date ... must be when it was bought? Maybe this weekend.
                        Thanks again. Merry Christmas to all.
                        Kent #6201
                        Kent
