qjets on 1969 Vettes - NCRS Discussion Boards
  • Jim 25993
    Can somebody point me to a document that gives the original part numbers of the parts that go into the assembly of the original qjets on the 1969 Vettes?
    • 43203
    Re: qjets on 1969 Vettes
    Jim-----
    Most of the parts would be shown in a 1969 edition of the Chevrolet Parts and Accessories Catalog. Subsequent editions of the Corvette P&A catalog (beginning in October, 1969 Corvette got its own P&A Catalog for the first time) would also contain the part numbers for most pieces, but each subsequent edition may include supercesive part numbers rather than the original part numbers. Also, at some point in later editions of the catalog, some parts would begin dropping out of the catalog as their final iterations were discontinued from the GM Parts System.
    • Clem Z.
      • January 1, 2006
      • 9427
      i have the delco rochester parts book,what part numbers do you need?
      • Jim 25993
        Gentlemen,
        Thank you for your response.
        My winter project is to rebuild the carbs on my 300 HP W/auto and 350 HP
        '69 vettes.
        The 350HP carb looks to be original (48K miles) but the 300HP is service dated
        although it still has a '69 date.
        I have purchase several correct number carbs for spares, and they are all slightly different. Probably due to the rebuilders consolidation process. At a minimum, I would like to know the correct metering rod numbers and the the correct choke assembly part numbers.
        Thanks again,
        JimA.
        • Clem Z.
          • January 1, 2006
          • 9427
          need the carb numbers
          post the numbers stamped vertically on the drivers side above the secondary throttle shaft. should start with either 70 or 170.
          • Jim 25993
            Re: need the carb numbers
            The numbers are:
            7029202 300HP W/Auto
            7029207 350HP W/Manual
            • Clem Z.
              • January 1, 2006
              • 9427
              7029202, sec rod 7034320/AN,pri jet #67,pri rod #42,vacuum break 7038239,fast idle cam 7036820, vacuum break rod 7038167,choke rod 7036067, vacuum break and bracket 7037501. 7029207, sec rod 7034822/BG,pri jet #66, pri rod #36,fast idle cam 7036819, all the rest of the parts are the same as carb # 7029202
              • Jim 25993
                Thank you very much for the help, I really appreciate it.
                JimA.
