1973 Door Ajar/Theft Door Switches - NCRS Discussion Boards
  • Roger S.
    • May 31, 2003
    • 262
    According to the wiring diagram each door switch is to have three wires going to it;white-alarm, blue-door ajar and black for the ground. Upon working on mine I notice each switch has two wires; one blue and one white. When either wire is touched to the surrounding metal piece in the body that holds the switch the door ajar light comes on. When the switch is installed and allowed to close the door ajar light goes on as it should. I bought an old switch from another 73 and it has three wires plus the switch is shaped differently. Mine is a very late model 73 - late July. Is this switch, wiring method and mounting method for the 1974 models or is it a "modification" by the person whom did a partial restoration?
    Roger
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1973 Door Ajar/Theft Door Switches
    The switches were changed around Jan 1973 from 3 wire round bottom to 2 spade contacts with a ground wire added to the metal plate.
    Lyle
    • Michael W.
      • April 1, 1997
      • 4290
      My July 3rd car has the same two wire switches as yours.
      • terry westrick
        I also have a July 73 that only has the two wire switches.
        • Harmon C.
          • August 31, 1994
          • 3228
          Mike My Nov.72's have the 3 wire type and I'm not sure about my Jan.73 454 and I don't want to mess with something that works ok to see what it has.
          Lyle
