power master cylinder - NCRS Discussion Boards
  • Gary 38683
    What is the correct #for 1967 power brakes master cylinder. The vendor says that
    #5455509 is for no power but I have been told that it is correct. Is there a
    modification that has to be done? Getting lots of different answers here. HELP
    Re: power master cylinder
    Gary -
    The vendor is confused - 5455509 was used for both power (J-50) and manual cars; the 346 was used only on J-56 H.D. Brakes.
    • Rob A.
      • December 1, 1991
      • 2126
      THE MASTER CYLINDER ON MY CAR, WITH J50 POWER BRAKES, HAS CASTING#5460346. IT IS THE ORIGINAL, FACTORY INSTALLED UNIT. I GUESS, AS ALWAYS, THERE ARE EXCEPTIONS.
        • 43221
        Rob-----
        That's the first '346' I've ever heard of on a J-50 1967. It surprises me, too. For an item like a major brake component, I would not think that the factory could have gotten deviation authority very easily from Chevrolet Engineering. The '346' is a 1-1/8" bore master cylinder; the '509' is a 1" bore. For 1968 and up, 1-1/8" bore master cylinders were used for ALL power brake Corvette apps. But, that was for 1968+ and not 1967.
          Rob -
          That falls into the category of "possible, but highly improbable", and, in any event, is incorrect to both Engineering and judging specifications.
          P.S. - Please turn off your "Caps Lock" key - standard internet protocol says caps are considered to be shouting, and it makes the post harder to read
