Intake sheet metal heat shield. - NCRS Discussion Boards
  • Mike H.
    • April 1, 2002
    • 57
    What is the best way to reattach the sheet metal heat shield to the bottom of a cast iron intake manifold? I am considering tapping the holes and using machine screws, but there probably is a proven alternative.
    • 43203
    Re: Intake sheet metal heat shield.
    Mike----
    Drilling and tapping the existing holes for sheet metal screws is the best way to do it. Install the screws with Lock-Tite. NEVER reuse the original serrated shaft studs, though. If you choose to use the original-type studs, then purchase new ones under GM #10229247.
    • Mike H.
      • April 1, 2002
      • 57
      Thanks again, Joe. Since my local Chevy dealer has the new rivits in stock, I'll go that route.
      • Clem Z.
        • January 1, 2006
        • 9427
        even with the rivits
        use red loctite to be safe.
        • Mike H.
          • April 1, 2002
          • 57
          Re: even with the rivits
          Thanks for the heads up on that one, Clem. The new rivits actually have multiple external splines as compared to the ones removed with three indented areas, causing the rivit to swell / swedge. They appear more robust and, with the red locktite, I am sure there is no danger in them coming loose.
