C-3 Rear Gear - NCRS Discussion Boards
C-3 Rear Gear
  • John D.
    • August 31, 2001
    • 280
    C-3 Rear Gear
    My 68 is supposed to have a 3.70 to 1 ratio. Any way to check the ratio without pulling it apart?
    Thanks, John D.
    Re: C-3 Rear Gear
    Yes, in fact with these cars as old as they are typically having gone through multiple hands, I advise testing to confirm exactly what ring/pinon setup is actually 'living' inside the rear end today!
    Get the rear tires off the ground (preferably on a lift). Put a chaulk mark on the drive shaft and one on the tire. Slowly/carefully rotate the marked rear wheel and count the number of rev's it takes to get the drive shaft to spin once. You'll empirically determine the rear gear ratio (4.11:1, 3.55:1, Etc.).
      Re: C-3 Rear Gear
      The 3.70 was available in both open and Posi versions in '68; if it's "open", the wheel on the other side will turn in the opposite direction when you turn one side. In this circumstance, have a helper turn the other wheel one full turn as you're doing the same thing on your side. If it's a Posi, turning one side will also turn the other side in the same direction.
      • Jim T.
        • March 1, 1993
        • 5351
        Re: C-3 Rear Gear
        What letters did you find stamped on the unit?
        • John D.
          • August 31, 2001
          • 280
          Re: C-3 Rear Gear
          1AO1067
          AO = 3.70 posi
          Build date 10/6/67
          1st shift
          Right?
