74 ride height - NCRS Discussion Boards
74 ride height
  • Tony
    74 ride height
    I have a 74 that seems to be alittle high in the rear. The rear height 30.5 inches from ground to fender and 29.5 for the front. What was the orginial ride heigth for this car?
    Tony
  • Michael W.
    • April 1, 1997
    • 4290
    My '73 is
    around 27.5" from ground to the top of the wheelwell openings at both front and rear with stock size tires.
    • Craig S.
      • June 30, 1997
      • 2471
      Re: My '73 is
      Tony - I have a 74, and it has the same 27.5" dimension Mike's 73 has. It would seem your car is high on both ends. Frequently aftermarket springs can get you into this situation...Craig
      • Edward McComas
        Re: 74 ride height
        The AIM has specifications for ride height. As I recall, the AIM measures the height of the body's lower edge (below the rocker panel covers) inboard from each wheel. It is something like 8.2 or 8.4 inches from the ground to this point
        on the rocker panel. This spec is in the first couple of pages of the AIM.
        • Tony
          Re: 74 ride height
          Thanks all I put in the 8" bolt and the height dropped to 27.75" I am happy now and the car handles better.
          Tony
