C1 Fan Shroud - NCRS Discussion Boards
C1 Fan Shroud
  • Brian W.
    • September 30, 1990
    • 216
    C1 Fan Shroud
    Judging guide states shrouding is painted semi-flat black. Most I've seen appear to be a semi-gloss black. Which is correct? Thanks
    Brian
  • Rob Dame
    Re: C1 Fan Shroud
    It depends on whether the can you are using is half full
    or half empty.
    I believe they are one in the same.
    Rob
    • John M.
      • January 1, 1999
      • 1553
      Re: C1 Fan Shroud
      Brian,
      I belive that the JG is wrong on this issue. The blackout paint would be acurately described as semi-flat in gloss, while the shroud would be more semi-gloss to gloss in sheen.
      Regards, John McGraw
      • Dennis A.
        • April 30, 1999
        • 1010
        Re: C1 Fan Shroud
        I used Semi-Gloss Black on both the engine fan blades and the shrouds. I believe this is correct. Sure looks good anyway.
          Re: C1 Fan Shroud
          I'm with John - the engine compartment (body) blackout was done with a semi-flat paint, but the (steel) fan shroud was dip-primed prior to installation; the dip-primed parts exhibit a higher gloss level than the engine compartment blackout - I'd call it semi-gloss.
