C1 Wiper Motor - NCRS Discussion Boards
C1 Wiper Motor
  • Rob Dame
    C1 Wiper Motor
    The wiper motor currently in my 56 is # 5047905.
    I think this is for a 56 Bel-Air but not sure.
    This car does have washers and the JM says the
    wiper motor should be # 5047924.
    Does anyone know if these two motors are configured
    the same with the top plates being interchangeable
    or do I need to hunt up a 924 Motor?
    Thanks in advance Rob
  • Mike G.
    • April 30, 2001
    • 180
    Re: C1 Wiper Motor
    5047905 is for a '57 Chevy, I believe. I bought one at a swap meet and the guy seemed pretty sure, at least.
    I don't know how well it would work with a '56 Corvette, but I know that I would have had to alter the mounting bracket to get it to mount on my '58. It is also only a single speed motor. For '58 Corvette, we need two speeds. Again, I don't know the '56 situation, though.
    • Rob Dame
      Re: C1 Wiper Motor
      Noland's book suggests that the wiper motor # should be
      5047223 for a 56. I've been told when in doubt go with
      the JM. I can't find this 5047905 # anywhere.
      Rob
      • Gilbert Scrivner
        Re: C1 Wiper Motor
        My 1956 Duntov has wiper motor number 5047924.
        • Rob Dame
          Re: C1 Wiper Motor
          Thanks Gilbert, Does it also have windshield washers?
          Rob
          • Brian W.
            • September 30, 1990
            • 216
            Re: C1 Wiper Motor
            My early 57 has wiper motor 5047988, what car would this be from? Judging guide states I should have motor 5047984. Is there a difference between these two motors?
            • Gilbert Scrivner
              Re: C1 Wiper Motor
              Ron, my 1956 does have windshield washers.
              • Roy Braatz
                Re: C1 Wiper Motor
                I don't now if you have a early or late 56 , but early used #5047799 same as 55.
                • Rob Dame
                  Re: C1 Wiper Motor
                  Roy, my car is # 316 about March 1st I believe.
                  What motor # would you think it should have and do you
                  know what the 5047905 would be for?
                  Thanks Rob
                  • Bernard M.
                    • August 31, 1994
                    • 341
                    Re: C1 Wiper Motor
                    Rob, My 56 has a 5047909 stamped on the switch cover. It is a mid-April build car. The motor is two speed and the car is equiped with washers. I have an older Dr. Rebuild catalog that lists the w/s wiper motor switch cover plates for sale as separate items. I'm not sure if they're still available. The main difference I've seen between motors is the shape. Some have a radiused corner while others are square, so the switch covers are not necessarily interchangable.
                    • Rob Dame
                      Re: C1 Wiper Motor
                      Bernard, I don't see the 909 listed anywhere either for a 56
                      Rob
                      • Bernard M.
                        • August 31, 1994
                        • 341
                        Re: C1 Wiper Motor
                        Rob, 7924 is what is considered correct. The switch cover on mine is nearly identical (only the number distinguishes them). The correct cover will have a metal sliding switch mechanism as opposed to the 1957 and later plastic one, and a radiused right rear corner, as opposed to the earlier (1955) 7799 switch, which also has the metal slide, but has a square right rear corner.
                        • Geoff C.
                          • May 31, 1979
                          • 1613
                          Re: C1 Wiper Motor
                          Rob,
                          My 56 is VIN 277. Tomorrow I will try and look at it. Its on top of a lift and everything depends on the bottom one starting. Mine has washers too. It was Top Flighted at a National, but that was years before I bought it.
                          Geoffrey
                          • Gilbert Scrivner
                            Re: C1 Wiper Motor
                            My 1956 is a August car vin #4026. It has two speeds and washers. It's number is a 924
                            • Rob Dame
                              Thanks to all responses *NM*
