More replies below current depth... - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11325
    John, Rob, Gary, et al.....
    So I read all of the previous Help Section threads about:
    More replies below current depth... (this is a link that now points to my search. latest discussion was 2008)
    and I see that based on the mode used this is the reason. (I use Hybrid Mode)
    Is there any way that the tree sizes can be increased to avoid this? I get very confused sometimes when researching and in several cases I've occasionally missed some very important info because of this anomaly. I bet I'm not the only one.
    John, back then you mentioned in one of the above threads that you were going to check it out. I truly understand your likely slammed these days but maybe you can put it on the wish list when you can. If I could help in any way let me know.
    e.g. Gary C. just posted a thread........
    https://www.forums.ncrs.org/showthre...79373&uid=6701
    about some potentially new discoveries about '57 HT only cars and I went to it and the anomaly was there when you go to his reference link....
    https://www.forums.ncrs.org/showthrea...=2305#poststop
    I bet others who may have Gary's answers will read the reference thread he added(above), and miss some great info that John Hinckley posted, because his replies were....."below current depth..."
    Rich
  • John W.
    Administrator
    • November 1, 1974
    • 5089
    Re: More replies below current depth...
    Richard,
    Thanks for the reminder. I did finally find the proper setting to change. Event though it looked like there were 15 posts shown before the "More replies below current depth..." message I found the setting was 10. I changed it to 25 now. That should make a big difference. If it needs to be higher I may remember some day what I changed and how to make it even higher.
    Administrator
    www.ncrs.org
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11325
      John, That's great! Thanks for your efforts!
      Rich
