Adding pictures to post - NCRS Discussion Boards
  • John S.
    • May 4, 2008
    • 424
    Need some advice on how to add or attach pics to my post. Have tried many times with no success. Are the file sizes limited? Please advise.
    John (48993)
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
  • Martin N.
    • July 30, 2007
    • 594
    Re: Adding pictures to post
    JOHN-
    If you search the archives you'll find all kinds of help regarding this issue, I also had troubles to begin with and a little patience and help from the archives I can now get them posted without issue.
    Size wise, I believe you're limited to 800 x 600 and you should be able to re-size the picture you want and then post it.
    Good Luck....Marty
    • John S.
      • May 4, 2008
      • 424
      trying again!CIMG1575
      John Seeley
      67 Black/Teal
      65 Maroon/Black
      • John S.
        • May 4, 2008
        • 424
        here we go again. Doing this on a mac. Is that my problem?
        John Seeley
        67 Black/Teal
        65 Maroon/Black
          • 15606
          John,
          There is a separate section of this forum devoted to HELP. There are numerous questions and explanations of how to post pictures there. There is also a TEST section. You are nto the first to have issues with posting pictures.
          At the top of this page will be an open folder followed by the underlined words "NCRS Discussion Boards" Click on that phrase and you will get a page that lists "Technical Discussion" (this section), "Discussion Board Help!" (where all the picture issues are, along with lots of other interesting material of a non-technical nature), "Technical Discussion Archives," "Test Forum" (where you can test the posting of picture, use of an avatar, etc.)
          Edit add: Well I see you succeeded with the picture. Good for you. I am not Mac literate, so I can't tell you if that was your problem.
