Advertiser's Link Button - NCRS Discussion Boards
  • Kevin G.
    • February 1, 2005
    • 1076
    Sorry, but I don't see the link button? Should it be in the large blue header bar above? Kevin
  • John W.
    Administrator
    • November 1, 1974
    • 5089
    Re: Advertiser's Link Button
    Kevin,
    Yes it should be in the big blue bar above. It is the fourth item over on the bottom row on my screen. "Visit Our Advertisers"
    NCRS Lingo Defined Coming Events Submit Driveline Ad Visit Our Advertisers Driveline Online
    If it doesn't show up on your screen in that way what do you see? The menu is generated based on your log in status, but the "Visit Our Advertisers" link should show up if you are logged in or not.
    Administrator
    www.ncrs.org
    • Kevin G.
      • February 1, 2005
      • 1076
      Hi John, You might recall we met briefly in St. Charles and I had asked this same question. It was a busy week so I can understand if it slipped your mind. In the blue header bar on the bottom line, fourth column over (under publications) my screen is blank?
      Thank you, Kevin
      • John W.
        Administrator
        • November 1, 1974
        • 5089
        Kevin,
        Thanks for the reminder. I found the problem and you should now see the link. A setting had changed. Not sure how that happens but it did.
        As administrator I have a slightly different view of the Tech Board than registered users. I don't get to see the board from your prospective, so I miss things like this. When problems like this crop up I depend on your help to figure them out.
        Thanks again for pointing this out to me.
        Administrator
        www.ncrs.org
        • Kevin G.
          • February 1, 2005
          • 1076
          Thanks for the help, but the link still does not appear? Is it a problem on my end? I did log off then on again?
          Kevin
          • John W.
            Administrator
            • November 1, 1974
            • 5089
            Kevin,
            Are you using the AOL Browser?
            Administrator
            www.ncrs.org
            • Kevin G.
              • February 1, 2005
              • 1076
              Originally posted by John Waggoner (107)
              Kevin,
              Microsoft Internet Explorer to log on the internet. Is that what your asking?
              • Kevin G.
                • February 1, 2005
                • 1076
                John,I just downloaded AOl Explorer and I'm still having the same problem, the space above is blank. Hopefully this will help others as well?
                • John W.
                  Administrator
                  • November 1, 1974
                  • 5089
                  Kevin,
                  You may be getting at least part of the page from the cache. Try a hard refresh by pressing the CTRL key and the F5 key together. That should refresh the page, and call up the new page from the server instead of the cache.
                  I don't have the AOL Browser available to me here but I have logged on as a regular user with I.E. and I do see the correct links in the menu bar.
                  Administrator
                  www.ncrs.org
                  • Kevin G.
                    • February 1, 2005
                    • 1076
                    Still no luck John. I have tried to refresh as you requested along with logging off on both Internet Explorer and AOL Explorer. I logged off the TDB and restarted my computer as well. I guess the advertisers don't want my buisness? lol Just joking Are there any other members experiencing the same problem?
                    Thanks for all your help,
                    Kevin
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17746
                      Kevin, take a screen shot (alt/print screen to copy and then shift/insert to paste into the e-mail) and e-mail it to John. Thanks, Gary....
                      NCRS Texas Chapter
                      https://www.ncrstexas.org/
                      • Kevin G.
                        • February 1, 2005
                        • 1076
                        Done, thanks Gary, John request the same. John signed on using my name and the link showed up on his screen. However it is still not appearing on mine?
                        Kevin
                        • John W.
                          Administrator
                          • November 1, 1974
                          • 5089
                          Here is a screen shot of Kevin's Menu Bar. Anyone else see the blank where Visit Our Advertisers should be?
                          Administrator
                          www.ncrs.org
                          • Rob M.
                            NCRS IT Developer
                            • January 1, 2004
                            • 12789
                            Can we get a dump of the HTML source (right click the browser window and select View Source (or something similar since I have a Dutch version of Windows). Copy and Paste the appearing code and mail it to John or myself to investigate...
                            greetigns,
                            Rob.
                            Rob.
                            NCRS Software Developer
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17746
                              Kevin, Rob would like for you to do the following:
                              1 - position cursor over menu bar where the blank spot is
                              2 - depress right button on mouse and selected "view page source"
                              3 - highlight the text and copy into a Word doc or an e-mail and send to John
                              Thanks, Gary....
                              NCRS Texas Chapter
