Can't move on after page 1 - NCRS Discussion Boards
  • Tom S.
    • March 1, 2004
    • 1087
    I see no way to go to page 2 or 3 or whatever. When the first page is full I can't figure out how to read more posts? You should be able to click on page 2-3 or whatever!Help!Tom
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12755
    Re: Can't move on after page 1
    Tom,
    I believe this depends on the view mode you've selected. In linear mode there should be page numbers at the bottom of the screen to select if more then the max. number of posts per page is reached. I'm not sure how the threated and hybrid mode works in this matter...
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12755
      Ok, I've checked a bit more. Click on the page nrs as shown in the picture attachment. These are shown both on top and at the bottom of each page with to many posts on all display modes...
      greetings,
      Rob.
      Rob.
      • Tom S.
        • March 1, 2004
        • 1087
        Rob
        Where do I change my view mode? I do not see anything at the bottom of the page to be changed! thanks Tom
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12755
          Select another Display Mode (nearly at the top of the screen on the blue bar).
          greetings,
          Rob.
          Rob.
          • Tom S.
            • March 1, 2004
            • 1087
            Rob
            what I was trying to say was when I am on a certain thread i can read 1-16. After that I can read no more posts. there is nowhere to click on page 2 for example. I am trying to read the posts on the NCM thread and I can only read 1-16 but there are 29 posts . How do I get to the last 13? Tom
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12755
              You are probably only looking down one branche of a tree using the threated or hybrid mode. Select the linear mode. I personally find it easier to understand...
              greetings,
              Rob.
              Rob.
              • Tom S.
                • March 1, 2004
                • 1087
                Rob
                I found it and that did the trick! thanks tom!
                • Tom S.
                  • March 1, 2004
                  • 1087
                  Rob thanks that did it! Tom
