Help - NCRS Discussion Boards
Help
+ More Options
Posts
  • Roy B.
    • February 1, 1975
    • 7044
    Help
    Get someone to help you change your setting (I`m not smart enough to) My settings have all the responses listed under original posts. You can scan thru them just like the old board. I kept changing mine until I got it that way but don`t exactly know what I did. Good Luck!
    A member sent me this , I would like to have my page the same way how do I do this?? thanks
  • David D.
    • January 1, 2005
    • 416
    Re: Help
    Roy....I 'think' this is what you need to do....
    Select either User 'Profile' or 'Quick Links'
    You should then see 'Edit Options'
    Then scroll down to 'Thread Display Options'
    There you should see a selection where you can do something like...
    • Oldest First Thread
    • Newest First.....
    • Old style
    • Hybrid
    There is a help area that explains each. All you have to do is pick the one ya want.
    When viewing a thread, you will be able to view the thread from a choice of four modes.
    1. Linear Mode (Oldest First) - In this mode, posts are displayed chronologically from oldest to newest. Posts are shown in a flat mode so that many posts can be viewed simultaneously.
    2. Linear Mode (Newest First) - This is the same as the above mode, except that posts are ordered in an opposite way (newest first).
    3. Threaded Mode - In this mode, a tree is shown along with every post. This tree allows you to see the relationship each post has to others, in terms of who responded to whom. Only one post is shown at a time.
    4. Hybrid Mode - This mode is a mixture of the linear and threaded modes. The post tree is displayed like in the threaded mode, but multiple posts are displayed simultaneously like in the linear modes.
    By the sounds of it, you'll want door #3 (Threaded Mode) but I'd recommend #4 (Combo of both worlds) unless that's what you already have.....
    Then Save (at bottom)
    Hope this helps.....
    David
    Disclaimer: I ain't that smart, so use at yur own risk
