Cookies - NCRS Discussion Boards
Cookies
  • George W.
    • November 1, 1993
    • 68
    Cookies
    How do I change the option for cookies form no to yes. Under "FAQ - Does this forum use cookies?" it states that "you may alter your cookie options at any time by changing the settings on this page." I can't locate this page. Could some one point me in the right direction?
    George
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12740
    Re: Cookies
    Hi George,
    We have customised the working of this forum a bit and now it does require cookies to determine if you are a legitimate member, therefor the usage of cookies is now mandatory...
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
    • John W.
      Administrator
      • November 1, 1974
      • 5087
      Re: Cookies
      George
      George,
      The FAQ is in error as Rob pointed out. Cookies are necessary for the site as modified to work right. The only option as far as cookies are concerned is when you log in it asks if you want to be remembered. Select yes to set your login information in your cookie
      I will edit the FAQ to make that more clear. Thanks for pointing it out.
      Administrator
      www.ncrs.org
      • George W.
        • November 1, 1993
        • 68
        Re: Cookies
        Thanks, Rob and John for the reply.
        George
