Search Help Information - NCRS Discussion Boards
This is a sticky topic.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    I've been experimenting with our new Search Functions. You nay notice some odd results in your searches based on certain keyword selection and option choices. vBulletin has sparse information on the subject, other than their "Search Tips".
    Here are some screenshots to get you started. It may be best to select Advanced Search for best results, particularly if you want a chronologically dated order of the results. Using the Basic search defaults with results to "Relevance", meaning it's own internal decision of ordering, with no regard to date order.
    Note that the Boolean functions are available, AND, OR, NOT(-). The default when multiple keywords are entered is "AND". I've included several examples below.
    When selecting Titles Only in your search, DO NOT use all 3 Boolean function terms in the same Keyword field. There is a bug which yields a error with no results.
    This is a Work-In-Progress. If you have other details please feel free to add your findings. At some point this may be added to our FAQ page.
    I'm also trying to understand if wildcards and quoted strings are allowed. I've experimented a bit with these options but seem to get inconsistent results. If I get better results or vBulletin confirmation I'll add that information here.
    Rich
    Inside the Technical Discussion you will see the Search box in the Upper Right area.
    Enter Keywords as needed. Example below "timing distributor OR tuning". Default between 2 or more words is AND.
    Clicking "Search Tips" below the Keywords field......
    Example of Results listed as Posts. You may see Yellow Highlighted keywords if near the top of the Post.
    Results. Notice the Keywords that you've selected are shown. This ensures your expected selection.
    This example uses all 3 Boolean functions. Note do not use "Titles Only" in this mode.
    Result
