Thread Post Order - NCRS Discussion Boards
Thread Post Order
  • Dan A.
    • February 1, 2004
    • 212
    Thread Post Order
    Since the TDB was updated the original comment in a post appears at the bottom with newer posts above it. Is there a way to change this? I’ve looked at settings, filters etc. but haven’t found anything.
    Thanks, and apologies if this has been covered.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17881
    Dan,
    Only setting to change display order:
    - click on User Settings - under your login Username upper RH side
    - click on Account
    - page down to Display mode
    There are only 2 settings. I use "Latest Activity" - Use this option to set which display mode you would like to see when you are on the conversation detail page
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John W.
      Administrator
      • November 1, 1974
      • 5098
      Don,
      At the top of the thread you will see three tabs. Posts, Latest Activity, Photos. Click on Posts. It will order them top to bottom in the order they were posted.
      Next click on the small down arrow beside your name up where you log in. Select Settings from the drop down menu. That will take you to your profile. Click the tab for Account. In those settings you will find Display Mode select Posts instead of Latest Activity. It will then default to Posts for you from then on.
      Somewhere there should be a setting to make that the default for everyone, I just haven't been able to find it yet.
      Administrator
      www.ncrs.org
      • Dan A.
        • February 1, 2004
        • 212
        John,
        Thank you very much, that took care of it.
