Photos using IMAGE button not full size in Posts - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    In the (recent) past, when adding a photo using the Image button, the photo would appear fully sized in the post and embedded where the cursor lies. A smaller thumbnail photo would then appear at the bottom of the post in the grayed area under "Attached Thumbnails".
    I looked in some previous threads and see it changed around the time of the new server upgrade. Good example of the "POST OLD PICTURES" sticky. All photos were previously fully sized, with the exception of some posts where the poster must have used Go Advanced and Manage Attachments process instead of the Image button.
    Now it appears that using the Image button, it shows the photo only as the clickable small thumbnail photo, not fully sized.
    Example using Image button. Not fully sized. It used to be fully sized using this method.
    Is this in fact a change when going to the new server? Can it be changed back to the way it was?
    However, if I add a photo using a copy/paste(of a enlarged photo), it remains fully sized.
    Example copy/paste.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17672
    Re: Photos using IMAGE button not full size in Posts
    Rich,
    None of the options changed when vBulletin upgraded.
    Unable to determine if that was a change in software. Does not appear there's any way to make it the insert Image function.
    Please test to see if the Image insert does full size image now.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Don H.
      Moderator
      • June 16, 2009
      • 2259
      I posted an image today using the Insert Image tool, and it came out thumbnail sized only.
      Trying it again now,
      well, now it's full sized, with no thumbnail. I'm happy with that.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        Now my post with the small image(1st photo) is now a full size image.
        Don, I see yours is too.
        Gary, did you change anything between when I first posted... and now?
        I also see the Sticky "Post Old Pictures..." has the most recent photos full size now too.
        Regardless, it appears to be back the way it was.
        edit add....trying again using Image button for full size.
        It shows up as thumbnail in edit mode, but when I Go Advanced and Preview, it's full size.
        I think it will stay full size when I Submit.
        edit... It did.
        • Jack M.
          • March 1, 1991
          • 1155
          THANX to Gary for working on this fix!
