Why does LOG ON to visit Driveline destroy my logged-in entry to the DB? - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    See Subject line
  • Arland D.
    Moderator
    • July 31, 1980
    • 430
    Re: Why does LOG ON to visit Driveline destroy my logged-in entry to the DB?
    See previous thread on this same subject.
    • Loren L.
      • April 30, 1976
      • 4104
      Forget the previous subject - if YOU COMPOUND THE FELONY BY ASKING THE QUESTION, YOU GET TO LOG ON AGAIN! Why not just fix it?
      • John W.
        Administrator
        • November 1, 1974
        • 5114
        Loren,
        As has been explained earlier your automatic login is controlled by the cookie on your computer. We have no way of troubleshooting much of what happens on your computer. I just tested logging into the TDB and then opening the Driveline with no effect on being logged into the TDB. A lot can happen that would affect the cookie on your PC. The best suggestion that I can offer is to delete the cookie and create the new one.
        Go to
        to
        https://www.forums.ncrs.org/register/ResetCookie.php to delete your cookie without affecting all of the other cookies on your machine. Once you have deleted it come back to the TDB and check the Remember me box and then log in. This will create a new cookie for you.
        If you would like to see what is in your cookie before you delete it and compare it to the new cookie once you create it go to: https://www.forums.ncrs.org/register/getCookie.php
        Copy and paste the results in Notepad or something. The go through deleting your cookie and resetting it, then take a look at the new cookie to see if there are differences.
        Hope this helps.
        Administrator
        www.ncrs.org
