Need help with adding file / photo - NCRS Discussion Boards
  • Ron N.
    • August 18, 2008
    • 243
    I tried adding an image to my posts on 1/26 and 1/27. I've done it several times in the past but it didn't work when I tried it on my posts on 1/27 and 1/27.
    I was trying to add a photo (JPG) clicked add image, selected the jpg (825KBS) from my computer, clicked upload the post appeared on the Forum but not the attachment. Tried a second time with the same results.
    Is there a size limit? What did it do wrong?
    I also want to delete my posts on 1/26 and 1/27.
    Ron
  • Don H.
    Moderator
    • June 16, 2009
    • 2287
    Re: Need help with adding file / photo
    Hi Ron
    are you using the picture icon in the small tool bar above the text box in your post? And if so, are you clicking on Basic Uploader?
    You should be.
    There should not be a size limit problem unless you are trying to load 4-5 MB files.
    Do you want to delete your posts from 12/26 and 12/27?
    Are these the ones that say photo is attached?
    If you send me your image files attached to an email to
    dgh50@att.net
    I can place them in a post for you,
    Don Hooper
    • Ron N.
      • August 18, 2008
      • 243
      Hi Don. Thanks for the response. Below is the answers to your questions
      1. I used the "insert Image" icon. Is that the same as the picture icon?
      2. After selecting the jpeg file on my computer I clicked on Upload. I presume it was the Basic Uploader.
      I do want to delete the 12/26 and 12/27 posts. They were the post I tried but failed up attached the photo.
      I'll sent you the image attached to an email at the address you provided. I would appreciate you placing the image in a post for me.
      Thanks for your help.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17971
        Ron,
        Members can only edit posts for twelve hours after their post is entered.
        Reason for the 12 hour limit is that in the past there have been problems with someone making a post, which caused a ruckus among other members, then the OP deleted their original post.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Ron N.
          • August 18, 2008
          • 243
          I'm Ok with that. I don't usually try to edit my posts. This was my 1st time to try to update the post because I was not able to add an image. Don has helped me understand the cause.
          Ron
