67 Front Caliper Bracket Finish? - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    What is the correct finish on the front caliper brackets on a 67?
    Dave
  • Peter J.
    • September 30, 1994
    • 586
    Re: 67 Front Caliper Bracket Finish?
    Cad or Zinc plated.
    • Ronald L.
      • October 18, 2009
      • 3248
      David originals show at Novi were plain heavy zinc plate as compared to the modern zinc di chromate that imparts a blueish and very glossy finish.
      • Stephen L.
        • May 31, 1984
        • 3162
        When I disassembled my original April 67 front caliper brackets, I found what appeared to be traces of a "gold" cad under the bolts. So, were they "gold" to begin with?
        I did replate them "silver" to avoid an argument at judging.
        Note the cad "runs" on the backing plates left from original plating.
        Check the photos below.
        • Ronald L.
          • October 18, 2009
          • 3248
          Steve, no gold cad, that is yellow chromate which could be applied over either but was predominate as a corrosion enhancer for zinc plate.
          A part print would solve this question
