NAPA Echlin ignition points (contact set) - NCRS Discussion Boards
    Over the years there has been confusion over the various contact sets sold by NAPA under the Echlin brand. There are a total of six applicable to Delco single point distributors not including the "uniset" that combines the points and condenser in a single assembly. NAPA also sells a price leader line called Mileage Plus and a couple of other sets in different brands.
    You can see them all at www.napaonline.com
    TDB member and NAPA jobber Tim Schuetz of Waukesha, WI also wanted to get to the bottom of it, so Tim sent me four of the six part numbers for analysis in boxes marked CS86, CS89, CS786P, and CS7860.
    Armed with a three-pound spring scale, mic, caliper, multimeter, and plain screw driver to partially disassemble the breaker arm leaf springs for measurement, I offer the following measured and visual observations. A summary of the measured data follows the discussion. All have screw type terminals rather than using the breaker arm spring to secure the wires like the old Delco D106P, a design I never cared for, but the old Delco D106PS has a screw terminal.
    Achieving consistent breaker arm tension readings required a little practice, and I found than listening to Bach during the measurements improved consistency.
    CS86: This set is listed on the Web site as "standard" and is equivalent to the OE points installed on single point Corvette distributors before '73 when the uniset became OE. The breaker arm tension is speced at 19-23 oz., and in addition to the main leaf spring, which is non-magetic or just slightly magnetic indicating stainless steel, there is a thin parallel leaf that appears to be copper and is likely there for conductivity. It is too thin to add breaker arm tension.
    CS89: This set is listed on the Web site as "high performance" and appears identical to the CS86, but main breaker arm leaf is .002" thicker, which increases breaker arm tension to equal the 28-32 oz. of the long-discontinued Delco D112P.
    CS786P: This set is listed on the Web site as "vented", but the set in the box was not vented and is most likely the CS786 discussed next. Other than the perforated contact pads, the CS786P is likely identical to the CS786. Vented points have been around for decades, and the theory is that they run cooler, which extends point life, but I have no personal experience and have never seen a scientifally conducted test.
    CS786: This set is listed on the Web site as "heavy duty" and has larger contact pads, which increases contact area by about 43 percent. Also, the breaker arm is a different design - different geometry - which made measuring breaker arm tension difficult, but it's basically the same as the CS86.
    CS7860: This set is also listed on the Web site as "high performance", and has the same spring thickness and breaker arm spring tension as the CS89, but it has some different construction details. The other three sets' breaker arm springs are retained to the breaker arm by a 90 degree tab that fits into a slot in the breaker arm. This set has no tab. Rather, the end mounted to the breaker arm is longer allowing it to be secured to the breaker arm with the rivet that retains the rubbing block. It does not have the thin copper parallel spring, but I could find no difference in resistance with my ohmeter that measures to about 0.1 ohm. All are essentially zero to 0.1 ohm resolution. The insulator is red rather than white on all the others, and the adjustment spring has blue Loctite.
    This set also has another interesting feature. Packaged with the capsule of grease is a small felt pad with a slot. The slot fits over the rubbing block, and the instructions say to grease both the rubbing block and felt pad. This should help retain grease and should be included with the other sets in my opinion. Despite this extra feature and what appears to be somewhat more robust construction, this is the least expensive set of the six!
    CS7860C: This set is listed on the Web site as "racing only", and I suspect it has higher than 32 oz. breaker arm tension. Since the 32 oz. sets will go to at least 7200 revs in a snug distributor, this set should not be necessary for any road-going Corvette with something close to an OE engine configuration.
    Part.........Spring.....Spring...........Contact.. ...Web site..............Online
    number.....tension,...thickness,......diameter.... comment.............price
    ...............oz..........in.................in.
    CS86........24..........0.018/.006.....0.152".......standard..............$16.49
    CS89........32..........0.020/.006.....0.152".......high performance...$21.49
    CS786......24...........0.018/.006.....0.185".......heavy duty..........$15.69
    CS786P....---...........----/-----......------......vented................$16.49
    CS7860.....32..........0.020/---.......0.152........high performance...$14.99
    CS7860C...---.........-----/---........-----........racing only...........$16.49
    My basic usage recommendations are as follows:
    1. Engines with redlines up to 5500 and the 1.8 ohm ballast - CS86.
    2. Engines with redlines up to 5500 and the 0.3 ohm ballast - CS786. The additional contact area might reduce the tendency to burn up points, which is not uncommon on systems with the 0.3 ohm ballast, especially in cold weather. Ballast resistance decreases with decreasing operating temperature and vice versa.
    3. Engines with redlines over 5500 - CS7860. This set is less expensive than the CS89 and has some better features.
    Proper distributor operation is necessary for peak engine performance - everything from idle quality to making it to the redline with no spark scatter or ignition breakup. It's possible that if you have a freshly blueprinted distributor, a standard tension set will make it to 6500 in a mechanical lifter engine, but in my experience, maximum high rev performance in mechanical lifter engines requires a 32 oz. set. As with many tuning parameters, what works in your distributor for you boils down to the condition of your distributor, your driving habits, and maybe some experimentation. My bet is that a majority of single point distributors out there are in need of a blueprint overhall, which has been discussed on the TDB many times. If the ignition system doesn't deliver a properly timed spark of sufficient energy for all engine operating conditions, the engine will never achieve peak performance and fuel economy. It's that simple!
    Nominal point life is about 30K miles, but can vary widely depending on ignition system configuration and condition. Since most of our cars have low annual mileage accumulation, it's a good idea to check that there is still some lubrication for the rubbing block at least every couple of years, and while you're at it, check point resistance and dwell angle. Dwell angle changes will effect initial timing, so checking initial timing is also a good idea after you have you checked and, if necessary, adjusted the points. Throw in the idle speed/mixture adjustment procedure and you've done a "minor tuneup" in less time than a wash job.
    A hearty thanks to Tim Schuetz who said he doesn't want the test samples back. My plan is to auction off the CS86 and CS786 at our So. Cal. Chapter meeting next month and donate the proceeds to the chapter, but for the time being, I'm going to hang on to the CS89 and CS7860.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: NAPA Echlin ignition points (contact set)
    Good analysis. Thanks
      here is what i used to check point tension back in the day
        Interesting you should post a photo of your small spring scale.
        The one I have was in a "Carter caburetor" box that I recall was black with some yellow in the artwork and the old art deco Carter logo. It belonged to my late father, and I remember first seeing it when I was a little kid - maybe six or seven years old. It was probably just an old Carter box the correct size for the spring scale and some other small tools. At the time I didn't know what a spring scale was. I just thought it was a neat box of stuff. It consists of a couple of concentric cylinders - chrome plated steel, about 5/8" OD. It's in very good condition - no rust at all. It will probably last several centuries with decent care.
        My dad probably had it since his days as a Pontiac zone service rep and Portland Zone Manager back before WW II - years before I was born.
        When my parents passed I kept the spring scale, but the box and other small tools disappeared.
        I figured it might come in handy someday, and I think this is the first time I used it since I brought it home in 1993.
        Thanks, Dad!
          The one I have was in a "Carter caburetor" box that I recall was black with some yellow in the artwork and the old art deco Carter logo. It belonged to my late father, and I remember seeing it when I was a little kid. It was probably just an old Carter box the correct size for the spring scale and some other small tools. At the time I didn't know what a spring scale was. I just thought it was a neat box of stuff. It consists of a couple of concentric cylinders - chrome plated steel, about 5/8" OD. It's in very good condition - no rust at all. It will probably last several centuries with decent care.
          Thanks, Dad!
          back in the day they used a pull scale with feeler gauge shim stock attached when they checked piston to wall clearance.
            We're on a real old-timers' roll, tonight, Clem.
            There is a picture of the operation you describe on Page 6-32 of the 1963 Corvette Shop Manual.
            IN FACT, the spring scale in that picture appears to be exactly what I have, but it must have a stiffer spring to achieve the specifiied readings. Page 6-42 calls it out as J-5513, Piston Fitting Scale. The only physical difference is that where the one in the picture has the feeler gage adapter attached, mine has an adapter with a length adjustable hook and jam nut. On close inspection I can see "Chatillon N. Y." engraved. Does anyone know if that's the manufacturer or a town?
            Imagine, all those years, and it's been right under my nose. Amazing!!! Thanks for setting my new understanding of this old tool in motion.
              i don't know about you duke but i am old and this cold weather here in Pa. is not making it any easier. off to Fla. the end of the week for a month and i hope the cold weather is gone when we get back.
              • Tim S.
                • May 31, 1990
                • 712
                Great information Duke. That was exactly what I wanted to see accomplished. Thanks for your efforts. Now I need to stock up on CS7860's!
                Tim
                  It's interesting that the CS89 and CS7860 are both active, yet functionally essentially the same. It would be interesting to know the history of these parts - when and why they were designed.
                  It's somewhat like the VAC situation. The B20 and B26 have essentially the same specs, but were sold under different part numbers. Someone finally realized this and both were consolidated under the same part number and eventually there will likely be one B-number, but in the past couple of years, those who ordered V-1765 got either one in the box.
                  Inventory control must be a huge issue in the auto industry both for manufacturers, jobbers, and retailers.
                  Do you by chance know how many active part numbers NAPA has?
                  The pricing is also mysterious. For example, why is the "heavy duty" set cheaper than the "standard set", and why is the CS7860 barely more than two thirds the price of the CS89?
                  Thanks, again, for supplying the parts for this project. I didn't get to watch any football yesterday, but I had a lot of fun playing with the contact sets.
                    HI Duke, Quite an impressive job you did on the NAPA Echlin points. And that's putting it mildly. I just printed it and will study it intensely. This helps clear up a lot of confusion in my feeble mind on the various point sets from NAPA.
                    A thanks goes out to Tim Schuetz also. John
                    P.S. This would make a great article for "The Restorer" for sure. Thanks for all your tedious work. Glad you missed the game.
                      If Vinny would like it for The Restorer, I'm happy to oblige. I'll need to do a little editing. That, of course, will increase the length from two to ten pages.
                        • 11669
                        I would just edit it, add photos and sent it in to him.
                        I'm sure he will love it.
                          Duke, The trouble with all this good info is I wish I had it an eon ago. Never have a seen such a comparison of the various points.
                          I have been racking my old brain trying to remember if the United Delco courses at the GM center had a gauge for measuring point tension etc.
                          I gave John Pirkle all my class books with exception of the FI ones.
                          If John and son are looking in please check sometime.
                          Back to work. Thanx, John D.
                            Yeah, I was just kidding. It really just needs a little editing. Despite several proof reads and typo corrections, it still has a couple left.
                            Photos can take up a lot of space, and there would have to be several close-ups to show the detailed differences, so that's a lot of space that wouldn't add much.
                            The data table pretty much says it all.
                              Would one expect to see some tolerances based on tests of a larger sample size? or could one extrapolate what that tolerance might be?
                              (Just a little fly in the ointment from a Pertronix user w/Dyna-Flite plate).
                              Fine work Duke. I certainly will print for my file and pick up a few sets to carry as backups.
                              Have a great day.
