Bolt On knock offs - NCRS Discussion Boards
Bolt On knock offs
  • Karl K.
    • November 17, 2008
    • 92
    Bolt On knock offs
    Hello everyone,
    I'm going to purchase a set of bolt on style knock off wheels
    for my 1965 coupe. What brand would be the most correct
    and best quality? Also I would be purchasing a set of radials
    with either white walls or goldlines, any recommendations there?
    Karl
  • Daniel K.
    • April 1, 2002
    • 190
    Re: Bolt On knock offs
    Karl,
    I purchased a set for my 65 several years ago from Corvette America. They have newly redesigned wheels and are offering a $200 discount. Other vendors will have these wheels as well. As for the tires, I'd go with Goodyear or other appropriate manufacture for your car. Have fun with your purchase and with your car.
    Dan K.
    • Daniel N.
      • June 20, 2010
      • 33
      I just ordered a set of Firestone FR380 white walls in the 205R75/15 size from Tires Easy. However, the white walls are only about 3/4" wide, whereas 1" is the "correct" width. If you have the car judged, any radial will get a deduction, but the correct white wall width with an OEM brand (such as Firestone) is a slightly smaller deduction. In that case, you should look at the radials offered by Diamond Back; they modify the FR380s (and similar tires from other manufacturers) to have the correct white wall width or to add gold lines. However, the cost for me would have been about $550 more for the modification for a set of four, so I ended up going with the stock Firestones.
      • Rick A.
        • 2147
        check VA Vettes - typically have package deals available on k/o's and tires
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
          • 43247
          Hello everyone,
          Karl
          Karl------
          There's no such thing as a "bolt-on, knock-off wheel". As far as the wheel goes, it's either a bolt-on OR a knock-off. It cannot be both. If you mean a knock-off wheel WITH A BOLT-ON ADAPTER, that's different 1963-66 Corvette optional aluminum wheels were of this type. 1967 Corvettes used bolt-on optional aluminum wheels.
            Joe -
            He's referring to the "direct-bolt" KO wheels made by Corvette America, where the wheels actually bolt to the hubs in the conventional manner, but have the cones and KO spinners that thread on as cosmetic rather than functional spinners; once installed, they look identical to the "knock-off" wheels.
              • 43247
              Joe -
              John------
              OK, I was not aware of those. So, what they are is a bolt-on wheel that looks like a knock-off wheel.
              • Scott S.
                • September 11, 2009
                • 1961
                John------
                Exactly. There has been at least one re-design in recent years, certainly in the case of the Corvette America wheels, and possibly also a redesign in the primary competing product, the wheels offered by America's Finest Corvettes.
                "Corvette America" wheels: http://tiny.cc/uj2yp
                "America's Finest Corvette" wheels: http://www.corvetteusa.com/
                • Henry A.
                  • May 31, 1990
                  • 107
                  I have a set of these wheels on my 63 Coupe. They are terrific! The look is great as well as the fit and finish. Mike has done a great job on these wheels and is a great guy to work with....
                  Henry Atsma
                  54 White/Red
                  63 Red/Black SWC
                  67 Elkhart Blue/Black BB Roadster
                  91 Black/Red ZR1
                  96 CE - LT4
                  07 Red/Tan
                  • Tom H.
                    • December 1, 1993
                    • 3440
                    Joe:
                    If you've never seen them, here's a link to what they are.
                    Tom Hendricks
                    Proud Member NCRS #23758
                    NCM Founding Member # 1143
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Does anyone know how these would do in judging?
