I know there are a number of threads addressing body lifting. But before I do this, I want to make sure I understand correctly are don't end up breaking my trunk or decklid hinges. I have attached a photo with the trunk hinge point circled.
Do I use this or the decklid hinge?
How do you attached a strap or chain to it? Put one or more bolts or eye-bolts through the hinge holes and attach a strap or chain that way? I really don't want to break any of these
I plan to use the radiator core support for the front lift points.
I can't use the soft top brackets as I have already removed them and the other soft top frame supports. I am going to use a 2 ton cherry picker for the lift.
Don Harris
Don Harris
