72 Exhaust clamp for tip - NCRS Discussion Boards
    • 6950
    Does anyone have a pic. of a original clamp for the exhaust tip for the 70-72 .
    Thanks, Ed
  • Michael G.
    • March 2, 2008
    • 485
    Re: 72 Exhaust clamp for tip
    Edward, Mine were long gone when I got the car. Paragon has what seems to be a decent repro. Haven't yet purchased them but they are described as the proper flattened arch of the u-bolt with stampings. No real photo in the catalog. Mike
      • 6950
      Mike, I just received my clamps from paragon today and am questioning there correctness, they recently had a new vender making them, I waited 3 months. I am thinking that these clamps or questionable. I would like to see a pic. of the correct one, to compare.
      • Paul O.
        • August 31, 1990
        • 1716
        Photos from 72 ZR-1 Bowtie candidate. Paul 18046
          • 6950
          Paul, thanks for the pic. thats what I needed. does that clamp have a letter stamped on it do you recall?
            • 43248
            Edward------
            Attached are photos of a Paragon-sourced clamp I got some time ago (although I think I might have purchased it from Dr. Rebuild). I think this is very close to being correct.
              • 6950
              Joe, that is what I have, the only thing is its plated cadiumn. I think I'll dip it in acid to removed the plating. according to JM its raw steel.
                • 43248
                Edward-----
                Yes, the originals were natural steel and you can easily remove the zinc plating from these. Keep in mind, though, that once you do, the "natural" finish is not going to last very long. It's going to VERY quickly appear rusty. I think that's why Paragon has these plated. It would be cheaper for them to leave them natural (as it was for GM).
                  • 15616
                  What you have Ed is, as Joe says, close; but if you look closely at the pictures Paul posted, and I think the pictures of the same car I sent to you, you will see the 1972 clamps are slightly different. The U-channel is not straight across on the original 1972 clamps. It is straight across on the 1970 and some 1971s.
                  BTW: The zinc can be removed with lemon juice -- acetic acid.
