1969 Stamp Pad - NCRS Discussion Boards
1969 Stamp Pad
  • Erv M.
    • February 21, 2007
    • 445
    1969 Stamp Pad
    I know it has paint on it. The pad/stamp looks original to me.
    Your thoughts?
    • 43287
    Re: 1969 Stamp Pad
    Your thoughts?
    Erv------
    I don't know about the pad stamp. The VIN derivative looks OK, but I'm not sure about the engine code stamping. In any event, the paint is not original to the engine. No Chevrolet engine was ever painted that "shade" of orange.
    • David L.
      • July 31, 1980
      • 3310
      Re: 1969 Stamp Pad
      The "T0130LM" code is for a 1969 Corvette 427 w/High Performance engine made Jan. 30, 1969 at the Tonowanda plant. The stampings look original to me.
      • Tom H.
        • December 1, 1993
        • 3440
        Re: 1969 Stamp Pad
        390 hp to be exact.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
          • 15640
          Re: 1969 Stamp Pad
          Erv------
          Nor was that quantity of paint used at Tonawanda or Flint.
          • Tom S.
            • March 1, 2004
            • 1087
            Re: 1969 Stamp Pad
            Pad looks good to me!
            • Erv M.
              • February 21, 2007
              • 445
              Re: 1969 Stamp Pad
              Well they definitely spruced the car up to make it more appealing to the buyer. It is a 427/390 4 speed car that looks good in pictures.
              I will probably make the trip to physically inspect the car before purchasing. One big problem there is no documentation, however the powertrain is all matching numbers.
              Engine was rebuilt, supposedly 1,500 miles ago. That explains the orange paint but most sellers tell you all components are fresh.
              We all must remember you can only con a greedy man!!!
              Is anyone located in the Portland area that could inspect the car for a fee?
              • Robert G.
                • May 31, 1990
                • 429
                Re: 1969 Stamp Pad
                It may be my monitor, but the 9's S and 5 bottoms all look lower than the 1's 7 and 4 bottoms. But I am not an expert.
                • Greg R.
                  • April 1, 2005
                  • 47
                  Re: 1969 Stamp Pad
                  Do the broach marks look legit ?
                  I would say yes...
                  Interested in others opinions.
                  • Dennis S.
                    • April 1, 2004
                    • 228
                    Re: 1969 Stamp Pad
                    That can quickly be dismissed by looking at the transmission stamp. If the same mentioned anomalies are present, that is golden. They were both stamped in St Louis, by the same person, with the same gang, at the same time. Pretty hard to fake an identical VIN derivative stamp in the cast aluminum transmission case.
                    • Erv M.
                      • February 21, 2007
                      • 445
                      Re: 1969 Stamp Pad
                      Here is a picture of the transmission
                      • David L.
                        • July 31, 1980
                        • 3310
                        Re: 1969 Stamp Pad
                        The "7" looks a little high and the "99" looks a little low both on the engine and transmission VIN stampings. It looks like both were made by the same gang stamp to me.
                        • Mike G.
                          • 709
                          Re: 1969 Stamp Pad
                          from what i can see both stamping and surface look good to me on both.
                          • Kenneth B.
                            • August 31, 1984
                            • 2091
                            Re: 1969 Stamp Pad
                            Not saying one way or another on this pad but if you restamp the block & trany with the same gang stamp the # will be the same. Bottom line if it looks like a duck quacks like a duck then we call it a duck even if it's not the original one you shot thet is on the dinner table.
                            KEN
                            • Dennis S.
                              • April 1, 2004
                              • 228
                              Re: 1969 Stamp Pad
                              KEN
                              I am sure blocks can be skillfully decked and restamped. The stamp on the transmission case...I guess one would have to find a blank casting (are there any?) and stamp it with both the correct date and VIN derivative. That is not a machined surface.
