1968 gas door hinge - NCRS Discussion Boards
1968 gas door hinge
  • Sal C.
    • December 1, 1984
    • 430
    1968 gas door hinge
    Are the hinges on 1968s (the ones riveted to the gas door) chromed or dull cad. All of the un-restored ones I see seem to be a dull finish to me.
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1968 gas door hinge
    Here you go Sal, #9643, dull.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Sal C.
      • December 1, 1984
      • 430
      Thanks Jack. Are those screws black?
      • Jack C.
        • 1090
        The screws are more brownish than black now however, not chrome.
        Jack Corso
        • Terry B.
          • 607
          Sal,
          The 4 black (now brownish) screws that Jack has attaching the bezel could also be chrome screws. Both types were used.
          Terry Buchanan
          Corvettes Owned:
          1977 Coupe
          2003 Electron Blue Coupe
          • Brandon T.
            • October 23, 2008
            • 872
            THe lid on mine doesn't stay up by itself I was told a spring to keep it up came in 69 is that true?
            or is my 68's lid supposed to stay up?
            thanks
            • Jack C.
              • 1090
              Brandon, no detent spring to hold it in the open position on the 68's.
              Jack Corso
              • Terry B.
                • 607
                I would think that the gas lid is suppose to stay up. The spring, from what I remember seeing, is rivited to the underside portion of the hinge area and is not reproduced. What I did with mine that had been broken long ago is to cut a small black rubber hose (smaller hose the better) about an inch long and then make a slice on the side of the hose. Place the sliced area over the hinge portion that slides next to the bezel and the friction with the hose and hinge holds the lid in place just fine. It's also hard to tell it's there unless you are looking for it.
                Terry Buchanan
                Corvettes Owned:
                1977 Coupe
                • Terry B.
                  • 607
                  Jack,
                  I see that the JM says there was no spring in 68 or 69 to hold the gas door open. Could this be wrong? I'm sure I've seen a spring. Please advise.
                  Terry Buchanan
                  Corvettes Owned:
                  1977 Coupe
                  • Jack C.
                    • 1090
                    Terry, I'll have to wait for a warmer day to go out in the garage and take mine off to take a look for any evidence that there was a spring there at one time. Nice idea with the hose.
                    Jack Corso
                    • John C.
                      • 616
                      There should be a spring to hold both 68 (late cars at least) and 69 fuel doors open. It is a U shaped spring that is riveted to the bottom of the door bezel. In 69 it also included a rubber bumper.
                      In the attached picture a 68 door is on the left and a 69 on the right.
                      John
                      • Terry B.
                        • 607
                        Thanks John for the pictures,
                        I knew I remembered seeing it. The spring wedges the door hinge and keeps it open.
                        Terry Buchanan
                        Corvettes Owned:
                        1977 Coupe
                          John
                          Thanks for posting the pictures John. My original owner FEB built 68 did come with the u-shaped spring to hold the gas door open. I gave up on getting a replacement spring. I personally searched through the GM Corvette parts book back in the early 80's. All I could find was the spring for a later year after 1970. Don't remember the exact year the spring design was changed. I ordered the later model one just to see what I would get. Totally different design spring.
                          My 70 uses the same spring setup as my 68. I still have the original spring for it, but it is not attached. I am considering using JB Weld to attach it.
                          Wonder how many 68-70 Corvettes do not have this spring anymore? I was lucky on my 70, it was still clipped to the raising portion of the hinge
                          • Terry B.
                            • 607
                            Jim,
                            Thanks for your confirmation of the spring. I hope earlier build original owners of '68 will help confirm the earlier existance of the spring too. Looks as if a change needs to be made in the '68-'69 Judging Manual when it says no springs held the door open in either 68 or 69.
                            Terry Buchanan
                            Corvettes Owned:
                            1977 Coupe
                              • 43273
                              Jim------
                              The 68-70 fuel door bezel assembly was an exceedingly poor design. The "hold open" spring FREQUENTLY breaks off of the "spun" rivets which retain it to the bezel. The spring was never available as a separate part from GM.
                              Many years ago, after replacing 2 of the bezels on my 1969 due to the spring breaking off, I converted my car to the 1971-74 design. From a functional perspective, this is a MUCH better design. By "notching" the bezel in the front, one can use the 69-70 style door WITHOUT removing the "hold down" bracket from the door. Then, if one wanted to return the system to the original style bezel for judging, it would only be an easy 10 minute job. Believe me, judging is the ONLY reason I could see to go back to the original design bezel.
                              Although I think that JB Weld would work to retain the spring, I think if I were going to repair one of these bezels, I'd simply drill and tap the bezel for small machine screws to retain the spring.
                              My BIG concern with the original design bezel: when trying to disengage the lid from the "hold open" spring, a significant amount of force can be required. I consider this deleterious to the rear deck and the paint on the rear deck. I can easily see where cracking of either could be "induced". Also, when disengaging the door from the "hold closed" device, the same sort of force needs to be applied in the opposite direction. I realize that the "hold closed" tension is adjustable but, under just about any circumstance, some significant force will be required to disengage the door.
                              The 71-74 design COMPLETELY eliminates the need for any force to be applied to open or close the door. In my mind, the ONLY way to go.
