Need help to ID this fan clutch assy - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Do any of you guys recognize this fan clutch assy?
    It is/was on my 60 and I'm trying to see if it should work on it or if it's too big(it just nicks the draglink when the steering is turned all the way).
    The only numbers I could see were on each of the blades and they are 912239.
    Thanks.
  • Stewart A.
    • April 16, 2008
    • 1035
    Re: Need help to ID this fan clutch assy
    Greg it's not an original fan so it could be to long in the blades. My car is closest when the wheel is in the straight position. When I turn the wheel the arm seems to drop away. The closest I get is a finger gap when the wheels are pointing straight. Is all your steering components original Greg. The original fan blade assembly is 3770529. It's hitting the pitman arm not the sway bar in front of the fan is that correct. Stewy
    • Mike E.
      • February 28, 1975
      • 5141
      Clutch is correct 61-62. Measure fan across tip to tip--longest distance should be around 17", as I go on memory.
