57 VIN question - NCRS Discussion Boards
57 VIN question
  • Bruce B.
    • May 31, 1996
    • 2930
    57 VIN question
    I'm looking at an early 57 (8xx) and the vin number on the title and vin plate begins with VE57S1008XX.
    I have seen vins begining with a V on some 55 Corvettes but never on a 57.
    Has anyone seen this designation before or possibly have an explanation for it?
    Thanks in advance.
  • Jimmy B.
    • July 31, 1980
    • 584
    Re: 57 VIN question
    The actual metal vin plate will not show a stamped "V", sometimes it could possibly be on the title though.
    Mike Hunt did an article on this many years ago.
    Jim
      • 17945
      Re: 57 VIN question
      Bruce, Mike Hunt's article that Jimmy refers to is attached. There are a couple of things on this low VIN car: 4 screws in column firewall plate, if 3 speed the shifter probably should have a spring on the outside of the shifter bracket on the passenger side and small shift pattern gate. No metal reinforcement under dash, rear cross Member with 5 holes in center section. Gary....
      • Bruce B.
        • May 31, 1996
        • 2930
        Re: 57 VIN question
        Gary,
        Thanks for the Mike Hunt info, excellent stuff.
        Is the complete Mike Hunt article available?
        Bruce B.
        • Michael P.
          • June 30, 1977
          • 31
          Re: 57 VIN question
          What "Firewall Column" plate are you referring to? Thanks
            • 8408
            Re: 57 VIN question
            stamped steel plate on engine side of firewall that encompases the sterring col mast jacket as it goes thru the firewall to engine comartment.mike
            • Michael P.
              • June 30, 1977
              • 31
              Re: 57 VIN question
              Gottcha, thanks
              • Kenneth H.
                • October 27, 2008
                • 500
                Re: 57 VIN question
                Bruce, I don't know the first thing about '57s (except that I don't fit in them), but I read the article that Gary attached and it seems from that article that ONLY the paperwork for certain '57s had the "V" suffix in the VIN. If the VIN on the VIN plate starts with a "V" I would be questioning the authenticity of the plate. Is it possible that the '57 is an actual "V" suffix 'vette with the original paperwork, but someone had a reproduction plate made and didn't realize the significance and usage of the "V"as stated in Mike Hunt's article?
                Thanks.
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Re: 57 VIN question
                  Ken,
                  I was mistaken, there is no "V" on the VIN tag.
                  I also read the info from Gary and it is very enlightening.
                  Thanks for bringing up the tag question.
                  Bruce B.
