160 Thermostat - Good or Bad? - NCRS Discussion Boards
  • William M.
    • July 31, 1993
    • 390
    1973 Big Block with AC.
    What are the pluses and minuses of using a 160 degree thermostat?
    Active debate is raging on the Corvette Forum regarding the effect on engine longevity. I trust you guys more. I'm listening ...
    Bloomington Gold 2011
    Corvette Magazine 9/11
    Bloomington Gold 2013
    Corvette Magazine 3/13
    • 43247
    Re: 160 Thermostat - Good or Bad?
    William-----
    First, you must keep in mind that the thermostat only controls the LOWEST temperature that the engine will operate at (after warm-up, of course). It does NOT control the maximum temperature that the engine will operate at.
    The cooling systems of Corvettes, especially big blocks, are generally not capable of maintaining a 160 degree temperature except in very low ambient temperature conditions or during prolonged downhill grades with the throttle essentially closed and the car zipping along at 60+ MPH. So, using a 160 degree thermostat allows a greater SWING in operating temperatures than is desirable---going from 160 degrees under a few operating conditions all the way up to 220 or 230 under other conditions. This is not a good thing.
    Beyond that, engines operate more efficiently at temperatures considerably above 160 degrees. So, rather than being beneficial, I consider 160 degrees to be detrimental. It was OK back in the 50's, but not for 60's and later cars.
    My recommendation: use a 180 degree thermostat for 1963-72 Corvette applications.
      what is even more important what temp does the oil reach as too low a oil temp causes the moisture not to be boiled out of the oil. on the dyno i have seen 18 HP difference with a 20 degree increase in oil temp
      • Dennis A.
        • April 30, 1999
        • 1010
        Does drilling a small hole in the Thermostat a good thing to do?
          Interesting HP increase with hotter oil. Oil temp with my 96 LT4 on the interstate runs about 204 and has a 195 thermostat.
          • Dan H.
            • July 31, 1977
            • 1369
            On the SHP and FI cars, what cooling effect does the thermostat bypass have when cold and hot?
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • Joe C.
              • 4598
              The trick is to keep the oil hot, the coolant about 40 degrees cooler, and the intake manifold cooler still.
              • Joe C.
                • 4598
                Dan
                Dan,
                I do not think that BBC water pumps have an internal bypass. All SBC, SHP engines have both external and internal bypass. SBC "water" pumps without an external bypass only have a much smaller internal bypass. BBC water pumps without external bypass have no bypass.
                One purpose of the pump bypass, is to promote a small amount of circulation before the thermostat opens, to ensure even heating on warmup. If your car does not have C60, then the water is always circulating thru the heater core, which provides the same function.
                • Martin M.
                  • November 1, 1979
                  • 124
                  Is this with A/C on, or off?
                  Marty
                  Beautiful Pahrump, NV.
                  No smog, no rain, no winter, no hurricanes, no tornadoes,
                  no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
                  vetteheads.com alumni, Boston MA alumni
                  1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
                  1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
                  1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
                  1957 Chrysler 300 C 392 Hemi Car
                  All for sale - most not cheap!!!
                    normally the oil temp is 10 to 30 degrees hotter that the water
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Depends on your point of view - In Arizona in summer the point is to let the water/coolant flow as soon as possible; achieving proper oil temperature will NOT be a problem.
                        yes but it is DRY heat correct ??
                        • John N.
                          • February 1, 1975
                          • 451
                          Clem
                          What viscosity oil were you using on that dyno test?
                          Regards
                          • Dale S.
                            • November 12, 2007
                            • 1224
                            I've never seen a engine sweat in Arizona. I hope this goes over better than my tire rental joke. Dale
                              Originally posted by John Neas (171)
                              Clem
                              Regards
                              10W-30 mobil 1 temp went from 180 to 200. to get accurate repeatable HP reading on a dyno the oil temp should be within 2 degrees and the fuel temp 5 degrees. the oil pump kills HP that is why NASCAR engines use 0W-10 for qualifying with the oil pressure turned down on the dry sump pumps and heated oil in the dry sump tank. some times they go too far and screw up the engine
