1956 single four distributor? - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    OK, here is the next question about 1956 single four barrel cars.
    What distributor did these cars use? Did they have a vacuum advance distributor or not?
    Re: 1956 single four distributor?
    1110872 or 1110879 (early and late with some overlap) neither used vacuum advance.
    • Scott S.
      • March 1, 1979
      • 747
      Ed,
      New listing TIJM
      1956
      210 HP
      1110866
      Vacuum/Cent
      D-3053
      Part # 1917247
      1956
      210 HP
      1110869
      Vacuum/Cent
      D-3053
      Part # 1917247
      1956
      210
      1110878
      Vacuum/Cent
      D-3053
      Part # 1917247
      Scott
      • Edward M.
        • November 1, 1985
        • 1922
        Scott;
        Thanks for trhe update.
        Where did this info come from?
        I have owner survey info on 3 known original single four cars. All three have an 1110879 distributor. Mike Hunt had an additional car in his survey, also with a 1110879 distributor.
        I have an 1110878 in my 72K original miles 56 Chevy four door sedan with powerpack engine.
          • 17932
          Ed, early cars principally 2 bolt '56 engines. What are the VIN's of the cars in your survey info? Gary....
          • Edward M.
            • November 1, 1985
            • 1922
            3809 and 4358 from Mike Hunt's data
            4411 and 4444 from owner surveys done for me.
            All show 1110879 distributor.
            There is one more, also a late car, but I can't recall the VIN right now. It also has an 879 distributor.
            Not sure there is such a thing as an early single four car. Single four engine became base motor as announced in Chevrolet Bulletin dated April 6, 1956. I believe that all cars prior to that were two four cars. That would put the earliest possible single four car (using April 6 as a rough starting date) at around #1800.
            I think we say that the change between 1st and 2nd design engines occurred around #1650.
              • 17932
              Ed, correction meant to say right after the early 2 bolt 1st design engines. Unfortunately, there's very little information available on any distributor use other than 879. Gary....
