Intake manifold gaskets - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Could someone please email me, post pictures or a template of the intake manifold gaskets for a 1961 283-CI engine? I have a set of Fel-Pro gaskets that I need to cut.
    Thanks Ray
    ray63@rochester.rr.com
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    • 8400
    Re: Intake manifold gaskets
    before the repo's became available, i used to trim the Fel-pro's to match the configuration of the originals but chevy engine orange didn't stick well to the fel-pros and judges could discern my modified gaskets. i now use Gary Pronesti's repos. think they are about 29 bucks a pair. mike
      There are two styles of repros now. Used to be Gary and others sold a one that fit all gasket. One that was supposed to be correct for 57 to 65 FI (wasn't only) and had the camel hump. Now a 2nd repro is identical to those except the top of the camel hump is cut off. It's supposed to be correct for 57 to 61 or so. I wish someone would chirp in here though and give us the whole story or the two style cuts of gaskets. Meanwhile both styles are made from Fel-Pro gaskets I believe. So the gaskets are NOT really repros at all. Just a readily available gasket that has been trimmed.
      • Tom P.
        • April 1, 1980
        • 1815
        I have an old, original gasket that I have been using for several years as a template to mark, then cut, gaskets from Felpro 1205 gaskets (which are black and has the ex crossover blocked).
          • 5196
          Here are some GM gaskets I have showing the configuration and part #..
