68-72 Actuator Relays - NCRS Discussion Boards
  • Steven C.
    • April 30, 2002
    • 199
    I have a shelf full of original, but leaking, actuator relay valves for early sharks. I know the catalogs sell repos but does anyone repair them?
    Re: 68-72 Actuator Relays
    Sal Carbone repairs them. Contact him at rpovette@aol.com
    • Pat M.
      • April 1, 2006
      • 1588
      What I've done is to buy brand new relays, still available from GM under #5638427, and carefully pry open the ring that holds down the top "pie plate". Then, I've gotten original 70 relays that weren't working, pried off the original tops, put those tops on the brand new relay body, and carefully re-crimped the ring back down. I then had the whole thing re-plated, resulting in a brand new, correctly-configured relay that works perfectly.
      • Steven C.
        • April 30, 2002
        • 199
        Thanks Dick and Pat.
        I assume the re-crimping is just a matter of snapping the top back on with no special tool required to re-seal it?
        • Bill C.
          • July 15, 2007
          • 904
          I had Bob Demmel rebuild mine. Did a GREAT job!
          Always best to keep the original ones and rebuild/replate them.
          • Pat M.
            • April 1, 2006
            • 1588
            No special tool needed, the re-crimped ring will seal the top against the rubber gasket. But you'll need a clamp to hold the top down against the large spring to begin re-crimping.
            It is a bit of a trick to pry the ring off in good shape, so I'd practice on an old one first and go slow. Also, for the best appearance, only pry open the bottom of the ring, pry open the minimum required to remove the top, and re-crimp the ring with the pried-open side down. Good Luck
