1970 LS-5 PCV Question - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello Everyone,
    On pg. # 79 in the fourth edition of the 1970-72 Judging Manual is states
    "On 1970 vechicles without the EEC system, the hose leading to the PCV valve is attached to the vacuum port on the carburator base and has a green spring clamp"
    It doesn't say how the PCV valve is attached to the hose at the valve cover end. Do I assume that it is also a green spring clamp?
    Could someone tell me what's correct - Thank you.
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: 1970 LS-5 PCV Question
    This is a picture of my 71 LS5 does it help?
    Kevin
      • 43250
      Originally posted by R. Kurt Neiman (38038)
      Hello Everyone,
      Kurt-----
      According to GM it had the same clamp on the PCV end as on the carburetor end. However, I believe that at least sometimes, the clamp was omitted in PRODUCTION. My 1969 was supposed to have the clamp on the PCV end, too, but it never did actually have a clamp at that location.
