60 Paint colors - metallic or non-metallic - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    My '60 was cosmetically restored 20 years ago and many of the paint traces were destroyed by covering up by subsequent paint. We raise the car on a lift and saw where a wheel weight had been removed and the color underneath appears to be turquoise. Could this be the right body color? (It's painted Horizon Blue/Ermine white currently) More imporantly, which 1960 colors were metallic vs. non-metallic? Was Tasco Turquoise metallic or non-metallic? Thanks for your help.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
    Re: 60 Paint colors - metallic or non-metallic
    Tasco Turquoise was definately a Metallic. My color charts are not at hand right now, but White, Red, and Black were the only '60 non-metallics I can remember, Honduras Maroon, Tasco Turquoise, Horizon Blue, Cascade Green, Sateen /Silver were Metallics. If I can find my color charts I'll double-check, but I'm pretty sure of the above.
    • Dennis A.
      • April 30, 1999
      • 1010
      Look behind the trunk/deck lid tower's for a second color look....for most painters don't spray there.
        Search the archives for more details, but the original color is usually written on the trunk bulkhead, hidden under the cover for the springs on the hinges.
        • Loren L.
          • April 30, 1976
          • 4104
          Or on the bulkhead behind the passenger seat.
          • Keith R.
            • August 31, 2001
            • 660
            Thanks Dennis. I'll look but when the car was repainted 20 some years ago I believe that was all shot over by the painter.
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Keith R.
              • August 31, 2001
              • 660
              Thanks all but I think that was all covered up by previous re-paints. When I got the car the previous owner had it up on sawhorses and was spraying it all white. Then I came behind and painted it Horizon Blue. Perhaps if I take a photo of the wheel area and fiquure out how to post it to the site maybe William or someone else who has a color chart can give me an opinion of whether it's close to Tasco Turquoise or not. Certainly looks more green than the on-line charts I've seen.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              • Garry B.
                • January 1, 1991
                • 660
                You have probably already checked, but most painters make very little effort if at all to paint the inside of the glove box on C1's. Anything there? Possibly towards the back of the compartment on the bottom.
                Good luck.
                Garry
                Garry Barnes #18531
                '67 Lynndale Blue Coupe- National TF, BG
                ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
                • Keith R.
                  • August 31, 2001
                  • 660
                  Hi Gary. Good idea. We're confident that the interior was black because of black paint remnants on the floor and tunnel under the carpet and inside the glove box is black. What I'm trying to do is validate the exterior color after the car had been painted two or three times over the past 25+ years. Wondering if some laquer thinner on the tunnel or behind the passenger seat would remove the old paint down to where some crayon marks might remain? Has anyone tried to do this? Thanks all.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                    • 8400
                    thinner will remove any crayon evidence before you'd visualize the crayon marking.mike
                    • Kent D.
                      • February 1, 1992
                      • 100
                      Scrape the paint off the trunk bulked on the passanger side and you will find your paint color.
                      Kent
                        • 11334
                        Kent
                        Here is my early 62 pass seat trunk bulkhead area, and my 59 trunk area behind the cardboard division panel. Unless prior painters removed all of the paint, it may still be there. The paint didn't stick very well to the crayon. Use a quarter and scrape the paint carefully in the area and it may appear.
                        • Garry B.
                          • January 1, 1991
                          • 660
                          Keith, I understand that you are trying to find the exterior color. When the car exterior is painted there is alway some overspray inside the glove box when they shoot the glove box exterior sides. The glove box exterior is the section that runs between the seats and is shot exterior color not interior color.
                          I have seen many older restorations that fail to paint the inside (backside) of the glove box door as well. This can also be a determinate.
                          Good luck.
                          Garry
                          Garry Barnes #18531
                          • Edward L.
                            • 278
                            Keith:
                            You can try scraping the right hand trunk bulkhead area as others have suggested, however, if there are numerous layers you probably won't have any luck with that approach.
                            Go back to the interior of the glove box. You state that it is black. If that is the only color that you can find in there, then you have your answer-the exterior of the car was black. The glove box was always painted exterior color on the straight axle cars.
                            • Garry B.
                              • January 1, 1991
                              • 660
                              I agree with Ed. If the only color that you can detect inside the glove box is black, you have your answer. They didn't typically paint the interior of the glove box, so the only paint that would have gone in there is exterior paint either from the exterior color of the glove box or from overspray from the convertible top compartment which was also painted body color.
                              Garry
                              Garry Barnes #18531
