Changed my gaskets (stock stamped steel valve covers) and realize that my 7 or 8 thread "A" headmark bolts are marginally too short to properly engage the thread holes in the heads. I would assume that 4 turns minimum would be required for proper retention, before torquing. Problem is made worse on a (set-up similar to a '67-up ?) radio car when the two braided shielded ignition wire eyelets are added to the "stack" which already includes the bolt reinforcement. Lesser but similar situation on a '65 with the one bolt that holds the clean (cold) air tube.
I don't have the '67 AIM or judging guide, but looking at the Long Island catalog, they show, for '65-6, all 14 bolts with RBW headmarks.
Then for 1967, it gets complicated
For no radio all 14 bolts have the same headmark RBW (same length as the ones for '65-6 ?).
Next they show a 10+4 set [RBW + SBC headmarks]; evidently the 4 bolts are for the locations where the plug wire shielding eyelets are held. Can I assume the SBC are the longer ones (how long) ?
Finally, LIC offers a set of 9+5 [RBW + SBC] for air conditioning (and radio, I assume). I'm guessing that with C60, there's one more SBC for something else that attaches under a valve cover bolt.
Anybody know lengths, or # of threads, on these various bolts ?
.For no radio all 14 bolts have the same headmark RBW (same length as the ones for '65-6 ?).
I might even paint two orange (Tonawanda) and leave 2 chrome (St.Louis)
will pick up on two cork=lam gaskets.........hope this helps.........k
