63 Reproduction tires. - NCRS Discussion Boards
  • Tom H.
    • December 1, 1993
    • 3440
    What has everyone found to be the most accurate reproduction whitewall tire for a January built 63 coupe ? What tire brand and company would you suggest ? The car won't be a driver, so I would just like the best replica of the original. I tried a search on the subject, which i know exists, but just can't seem to master the archive search feature here. Thanks in advance.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    Re: 63 Reproduction tires.
    Tom, Refer to the standard Judging Reference Manual for Tires. I see where you are coming from though. Your goal is to not loose more than the 10% deduct for repro tires. There is a wide variable on deductions. My 63 has 4 Coker tires on it and it received a 10 deduct. Original spare helped pick up some points though. Tires are Goodyear. Valve stems and caps are important also. Buy the way most use Dill valve stem caps even though others are exceptable and correct. I believe Shrader is one of them. We buffed the dot off my tires but got caught cheating. Don't try and cheat dem judges. John
    • Alan Drake
      Re: C2 valve caps
      Note the Dill 627 Caps are still available, however for 63 that may be a mute point since the JG does not specify - only for P48 on 64's. Stems appear to be about 1 1/8 not the 3/8 as called for (Data from Mar64 original spare)
        Re: C2 valve caps
        Alan, I believe the valve stems are longer for my 63. I would have to research my notes but I think there were about 1-1/2 long. Knockoff use a shorter one. I am sure guys will chime in here on this. The 627 Dill caps that are still available are not the same. Font is different. Size of the numbers are smaller than the olden days. Close but no cigar. I remember going to a local tire dealer who was a friend and spending hours going thru buckets of old valve stem caps getting the correct ones which have bigger letters and numbers for sure. Nit pickin I know. John
        • Tom H.
          • December 1, 1993
          • 3440
          Re: C2 valve caps
          Thanks for the help. Coker makes an acceptable tire, you think ?
          Tom
          Tom Hendricks
          • Alan Drake
            Re: C2 valve cap font
            Good catch, I never looked that close (with glasses on). So the old one's I found were still a find (one was on spare). Interesting that the 63 stem was longer, but not surprising. I bet that original sizes vary - again different vendors at different times. Never surprised at the details that one can find here.
            • Collin MacDonald
              I know the Goodrich tires/ww are correct and they fit in the spare tire tub. However the Firestone Champions are correct too, but they are about 1/2 too tall to fit in the tub.
